Results 1 to 3 of 3
Thread: Epson ABW vs Custom Monochrome Profile
    Feb 2015
    336
    I am profiling a few papers for use with my Epson P6000. I'm using a Color Munki Photo, and it's great for my color images. I definitely see an improvement over the manufacturer profiles. I can go in and refine the profiles further by inputting a particular image. I was thinking of inputting a monochrome test image and using that to create a custom B&W profile. But I'm wondering if I'm better off just sticking with ABW mode... I'm mostly printing directly from LR.
    I would appreciate any advice!
    Dec 2009
    Culver City, Ca.
    180
    Re: Epson ABW vs Custom Monochrome Profile
    Pretty sure that your ColorMunki only makes RGB or CMYK profiles and not Grayscale. You'd need a different app that can make GS profiles and then do a rather complicated Convert to Profile with your new GS profile then ASSIGN sRGB, which is what ABW wants, but you can't assign a color profile to a GS image, so you kinda see the problem. Really, the best and easiest thing is to do convert your file to sRGB and send that through ABW. It works amazingly well as that's how Epson designed it to work. And don't forget that it's not just the multiple black inks but also a small amount of the other colors as well to facilitate neutrality and color toning.
    Apr 2009
    Sydney, Australia
    597
    2
    If you are serious about B&W, I would avoid ABW. Itís easy but has limits. Have you looked at QTR?
    Jeff
    www.jeff-grant.com
