I have never seen it on my Z7, and if it has been there I haven't noticed it...Why they out the AA filter in the Z6? Is moiree a problem seen often in the Z7?
They probably found that FF sensors with lower pixel count (like the Z6) could show moire.Why they out the AA filter in the Z6? I moiree a problem seen often in the Z7?
Right, higher mp cameras don't show moire because of the denser array.They probably found that FF sensors with lower pixel count (like the Z6) could show moire.
If I am not mistaken, all of Nikon's FF cameras without an AA filter have at least 36MP.
Except for Leica-s, all FF 24Mp cameras have an AA filter. I prefer images from sensors without AA filter. While moire can be produced when the AA filter is omitted on 24Mp FF sensors, I have never encountered it (yet) in my photographs.They probably found that FF sensors with lower pixel count (like the Z6) could show moire.
Well, even with an AA filter on a 24 MP sensor you can get moire:Except for Leica-s, all FF 24Mp cameras have an AA filter. I prefer images from sensors without AA filter. While moire can be produced when the AA filter is omitted on 24Mp FF sensors, I have never encountered it (yet) in my photographs.
Hi John,I tried a Z7 w/24-70 for a week. I shot around a hundred images and got moire on two. Unfortunately I deleted them so can’t prove it here.
Any form with many lines or multiple repeating lines or squares can create moire. It can be dealt with in pp. And in many cases, moire that you see on your LCD or monitor will disappear when printed or enlarged.
I cant tell a big difference. One has a yelloish tint. both look like they received a lot of sharpening for my taste. But both do show same level of detail to me. My guess would be second is Z7......
Images show two different days. One with 24-70mmf/4 on the Z7 and the other shot with the Nikon 50mm 1.2 AI-s at f5.6 (I think) Both are at 100 ISO. Z7 was at 70mm and the Z6 was at 50mm. So, which is which?
Lastly, the Z's are simply the best tool for using manual lenses, period!
It’s a winner!Hi John,
so what is your conclusion about the Nikon Z7 in general?
I suspect that the reason there is an AA filter in the Z6 is that it is very much a video-oriented camera. Unlike still photography, it is nearly impossible to remove moire in video without resorting to heroic (read expensive) techniques.Why they out the AA filter in the Z6? I moiree a problem seen often in the Z7?
