Results 1 to 10 of 10
Thread: GRD-2 firmware update 2.01 is available
    Jerusalem, Israel
    1,280
    This was withdrawn for about a week because of a problem with support for a Sigma flash (which I don't have). Now it's back. It offers four usability improvements, two of which I could easily understand. If you don't like the green light glowing from the power button, you can turn that off. Also if you zoom in on a frame displayed on the LCD and want to compare with an adjacent frame, now the zoom stays on. And there are more buttons that you can zoom with.
    Makes you wonder why Leica has such a difficult time adding options in firmware that at least some users think might increase usability of the M8, doesn't it?
    scott
    belgļe
    1,492
    2
    Re: GRD-2 firmware update 2.01 is available
    major kudos to Ricoh for both! that damned green light has stopped me from taking pics at the opera and i love that you'll now be able to compare in zoom (i'm often doing this one-handed in rehab).
    now if only they'd turn off NR in JPEG....
    VladimirV
    Quote Originally Posted by cam View Post
    From my observations this has been improved a bit although still not turned off completely. But I can actually use a jpg straight out of the camera now and also check focus on the LCD in playback mode.
    Senior Member ecliffordsmith's Avatar
    Mar 2008
    Antwerpen
    467
    Scott,
    Thanks for the tip, I will will download this later.
    tkmloh
    Hi scott,
    Thank you for the update. I'm new here. By the way, i noticed i couldn't view the iso settings for the playback files in-camera when iso settings is set to either auto or auto-high. It is displayed only if the iso settings are set fixed. i.e iso100, iso 200 etc. When auto or quto-high iso is set, playback does not review any info on iso for shots taken. Anyone could verify this?
    Cheerio!
    ellemand
    Hi tkmloh.
    That's right - I never use autosettings, but I gave it a try - and you are right, it does not show in playbackmode.
    By the way - I have just downloaded and upgraded to vers. 2.01 - it works perfect (I don't have a Sigma flash, so I don't know about that feature.
    Cheers
    Ellemand.
    tkmloh
    Quote Originally Posted by ellemand View Post
    Hi tkmloh.
    Cheers
    Ellemand.
    Hi Ellemand,
    Thank you for the response. I always thought auto-high iso settings would be useful in difficult shooting conditions. Anyways, i hope the next firmware would resolve this. Shouldn't the display show the iso for the shot taken under auto or auto-high iso settings as opposed to fixed iso, which we would have known and selected manually in the first place? Thanks anyways...
    Cheerio!
    VladimirV
    I think the reason behind this is that Ricoh has nice icons for the ISO display but this only works with known settings such as ISO 100 and not ISO 162 since the icon is not dynamic. This is the same in all Ricoh cameras that I know.
    tkmloh
    Quote Originally Posted by VladimirV View Post
    Hi Vladimir,
    Thank you for your response. In terms of "nice icons vs user-friendliness", i would have preferred the latter. Don't you think so?
    Cheerio!
    VladimirV
    Yes, it would've been better indeed to skip the nice icons and rather have the correct information there. No idea why Ricoh chose to do it like this.
