Indeed, I like sean's view: buildings and such are part of the street, so concentrate on those for composition also!
have fun on the street, wouter, and love to see more!
http://www.flickr.com/photos/ronaldbunnik/
Buildings, mailboxes, everything... One of the things that Stephen Shore used to stress to us is that *everything* in the frame is subject. What we often call background, is still subject. The tiny figures that appear in the distance in a Breughel painting are still painted very specifically. We have to do the same with our medium. This is one reason that I personally love the "window finder" - the RF or accessory finder with no ground glass. It allows us to see deep space clearly. Mitch uses an alternate approach of using the LCD to find the edges and then direct sight otherwise.
One consequence, sometimes, of SLR photography is that one sees only part of the frame clearly, one distance from the lens, (because of limited depth of field) and so the other elements in the frame, the other subject matter, is not seen well and thus not visually resolved in the picture. It's not so much of a problem when one is working across short space, as Robert Bergman often is for example, but it can be a big problem when one is working across the deeper space of a street, a courtyard, etc.
There's a great correlation between small sensor cameras and window finders. The cameras tend to record with great depth of field and the finder shows us infinite depth of field. In case the following is of interest (this is from a review of the Epson R-D1):
"...There are photographers who prefer rangefinders and others who prefer SLRs. Needless to say, there are pros and cons to each system. Rangefinder cameras are usually smaller, lighter and quieter than SLRs. Since they don’t use reflex mirrors, they tend to have less vibration than SLRs during exposures and this can be an asset when working hand-held at slow shutter speeds. Their lenses tend to be compact. The core advantage of a rangefinder, for me, however, lies in the way in which it allows one to see and frame the picture before it’s captured. A rangefinder shows one the world through a window with lines indicating the picture’s borders. That allows one to look at what will and will not fall within those borders. In other words, one sees the world of the picture about to be made as well as the world just outside it. This can give one a greater sense of the ways in which the picture might change by either 1) changing the framing or 2) allowing elements outside the frame to move into the frame. Epson’s 1:1 finder takes this strength one step further. Since the finder shows the world at life size, one can work with both eyes open. One eye sees the world as it appears in the frame; the other watches the world outside the frame that may soon enter it. Or perhaps we could say that the right eye sees the trees and the left eye sees the forest.
Then there’s the issue of viewing depth of field. An SLR normally uses an automatic aperture that remains open during composition and only closes to its set aperture at the moment of exposure. So, let’s say the camera has a 50mm F/1.8 lens mounted and set to an aperture of F/8. The exposure will be made at F/8 of course but the viewing used to compose and choose the moment of the picture will be seen through the lens wide open. That means that one will only see a certain range of distance in the frame (usually the foreground subject) clearly, everything behind and ahead of that focus zone will be blurred. So while the film or sensor will “see” at F/8 when the exposure is made, the photographer sees at F/1.8. It’s hard for one to make a picture he or she can’t fully see. One can get around this using a depth of field preview button but that method tends to work better when the camera is on a tripod. When working handheld, using a DOF preview button can be cumbersome and makes for a dark finder where things are harder to see. The rangefinder has the opposite problem of showing all distances from the lens in focus. One process is additive and one is subtractive. With the SLR, one must see certain distances out of focus and imagine what they will look like in focus. With a rangefinder, one sees all distances in focus and must imagine what some of them will look like out of focus. I prefer the latter way of working."
Its interesting to note that photographers like Winogrand, Frank, Levitt, Koudelka, etc. continue (continued in the case of Winogrand) to work with rangefinder cameras long after SLRs had been popularized. Looking at their work, its clear how important it was for them to be able to see near and far all at once.
Sean
