Results 1 to 4 of 4
Thread: meso amrican class projects
    Jan 2008
    1,627
    dp1 and sigma flash.
    the full gallery at www.pbase.com/wwp/meso
    wayne
    www.pbase.com/wwp
    D upton-Hackett.
    Re: meso amrican class projects
    Terrific wayne.
    I avoid flash can't get my head around it even though i have the EF-140 DG that came with the DP2. Maybe one day...
    Jan 2008
    1,627
    the key, derek, is the flash compensation. (just found the instructions in the manual). you can raise and lower the power of the flash. also, by using iso and the ev compensation. if you use manual focus, and figure out the distances, you can shoot in the dark. i usually take practice shots to get it set up right. and in the flash wb mode they come out great. it's worth some effort as you can use it as a fill flash on the beach with people.
    wayne
    www.pbase.com/wwp
    D upton-Hackett.
    Thank you once again Wayne will have a try.
