Results 1 to 15 of 15
Thread: Fuji 200 EXR images at dpreview.com
    302
    They posted some images from both pre-production, production cameras including some comparisons of hr, dr, and sn modes.
    Perhaps a complete review is not too far off??
    Martin
    Senior Member Rawfa's Avatar
    Nov 2008
    Rio de Janeiro
    2,393
    Re: Fuji 200 EXR images at dpreview.com
    Here's the link http://www.dpreview.com/gallery/fuji..._beta_samples/
    There's some nice stuff there, but I'm not yet convinced this camera is the miracle worker compact people were waiting for.
    302
    Miracles are hard to do.
    I'd settle for some improved dr, and low light sensitivity.
    At least Fuji has recognized some of the problems with small sensor P&S, and has tried to address them.
    Martin
    Reproster
    Hi, there!
    funny camera...
    downloaded pics and compared in photoshop...sensor with potential... but from optical stand point the corners are crappppy ;(...
    why they try to avoid optical laws.........
    why they don't release such cameras with little-bit larger but better optical elements.........
    with good glasssss even 6 mpix will be enought!!!
    Apr 2008
    1,446
    does not really impress me. suspect the F31Fd or F30 would still do the same job for low light, and even has the same MP in low light.
    MAzor
    Lili's Avatar
    2,527
    I have had the F31 and save for one image, the church, I feel the new camera does as well and perhaps better than my old f31 would've.
    Add SD card compatibility, IS, and a much more useful zoom range as well as being new and in-warranty, it appears to be a winner.
    And that is with pixel-peeping the original files
    Senior Member Tim's Avatar
    Jun 2008
    Adelaide, SA
    1,040
    I can see a place or niche for this camera. Not everyone wants to process RAW files and if it can squeeze some more dynamic range or NR from an in camera jpg by some creative uses of the CCD then I think its got a place in the market.
    As Lili mentioned you get IS and more zoom over the F31. The IS0 800 sample didnt look too bad IMHO, maybe the release firmware will be even better?
    Nov 2008
    Rio de Janeiro
    2,393
    The thing is that for this price you could get a LX3.
    Lili's Avatar
    2,527
    Quote Originally Posted by Rawfa View Post
    The LX3 is far larger and has a less useful zoom range despite its speed.
    Apples and Oranges.
    nei1
    Is it obvious to everyone else how this camera takes 2 images at the same time?I dont quite get it.Or is it just taking one and inventing the other.
    Senior Member Will's Avatar
    Near London
    1,054
    Quote Originally Posted by nei1 View Post
    I presume it sets half the sensors to as slightly different sensitivity. So the high dynamic range images are half the pixel size.
    Apr 2008
    1,446
    wouldn't it be interesting if someone made a camera that had a prism in it to split the image into 3, so it could have 3 separate sensors each with one color filter and hence no need for bayer interpolation, and having 3 sensors instead one could improve dynamic range and sensor noise!
    I know they have done this with Video cameras, denoted with "3 CCD" but why not on a digital camera.
    MAzor
    Nov 2008
    Rio de Janeiro
    2,393
    Quote Originally Posted by mazor View Post
    MAzor
    In a way isn't that how a foveon sensor works?
    302
    Rawfa
    A Foveon sensor doesn't use a prism. The sensor has 3 separate layers each of which is sensitive to red, green, or blue light. The claimed advantage is that each pixel location will respond to the appropriate color of the subject without the need for Beyer interpolation.
    There are many discussions as to whether any significant improvement will be noted in color fidelity as compared to the Beyer pattern of photosites.
    Hope this helps.
    Martin
    nei1
    Quote Originally Posted by Will View Post
    Im sure youre right Will,but as it can only take one image then the other is a copy using the unused sensors,if its a copy why not use the 12 and copy 12?Would be nice to see an explanation of all this.All will soon be revealed Im sure.
