Results 1 to 7 of 7
Thread: D-lux3/LX2 hood/filter adapter
    Terry's Avatar
    New York City
    6,955
    1145
    I came across a post for this on DPReview and decided to order it. I've wanted to play around with some filters and close up lenses on the D-lux3. The adapter arrived today. It is very well made, fits perfectly over the outer edge of the rigid (non retracting) part of the lens, and can be adjusted to make it deeper or shallower.
    http://www.hkdcplus.com/page_gen.php...=PD07080800001
    I think it took a little under two weeks to get here from Hong Kong. Once I've had a chance to use it in the field, I will post some additional information.
    Here is the thread on DPReview. The picture didn't show for me the last time I went into the link but you can click on the blue "new window" at the bottom and it will open. I am not using and didn't buy the flower hood but apparently that is available as well.
    http://forums.dpreview.com/forums/re...ssage=26344638
    terry
    cadmium red
    Re: D-lux3/LX2 hood/filter adapter
    terry I have the D-lux3 as well so I'm curious what type or kind of close up lens can you put on this adapter.....patrick
    Chuck A
    Nice catch. This looks very interesting. Thanks for the info. Let us know how you like it. Is it snug enough that it won't easily fall off?
    Terry's Avatar
    New York City
    6,955
    1145
    Quote Originally Posted by cadmium red View Post
    I was using these for macro photography. Set the camera to manual focus and then move the camera back and forth until you are in focus on the LCD. The focus distance is about 12 inches (how far you need to be from the subject at any zoom)
    This is a pretty expensive one but it is considered a good one. The adapter gives you 52mm threads which this is:
    http://www.bhphotovideo.com/c/produc...e_up_Lens.html
    There are also very sharp close up lenses by Raynox that a lot of the Panny superzoom people use that are less expensive and they clip on and will work just fine
    This is the 150 which is +4 diopter the 250 is +8
    http://www.bhphotovideo.com/c/produc...acro_Lens.html
    Terry's Avatar
    New York City
    6,955
    1145
    Quote Originally Posted by Chuck A View Post
    It is snug enough. there is a rubber O ring in the inside the makes it snug, won't let if fall off and keeps you from rubbing metal over metal. I'm not easily impressed and build quality seems quite good.
    TMGraphics
    Really great information! Very interesting.
    Thomas
    cadmium red
    terry.....thanks for the informationp.....I love the idea of having the d-lux with close up possibilities.....so today it's "vamos a compramos" {lets go shopping} ,in Hong Kong. Patrick
