Results 1 to 16 of 16
Thread: DP1 hyperfocal distance
    Aug 2008
    116
    In a thread here on GetDPI I found these for the DP1 hyperfocal measurements:
    f4.0. 12.6'
    f.5.6 8.93'
    f8.0. 6.33'
    f11. 4.49'
    In practice, what does this mean? At F/4 you should, in general, focus 12.6 feet away for optimum image sharpness within the depth of field? Does this mean that I can set the manual focus wheel to approximately 12.6 feet and most shots will be in focus. Does this have anything to do with zone focusing?
    I've Googled hyperfocal distance and I still don't grok it. Perhaps I'm just dumb Any helpful hints or clarity appreciated! Thanks.
    Subscriber Member Streetshooter's Avatar
    Jul 2008
    1,431
    17
    Re: DP1 hyperfocal distance
    That's from my post and it translates like this....
    if you focus at the hyperfocal distance then,
    the DOF, (Depth of Field) will be from 1/2 of the hyperfocal distance to infinity.
    any questions ya can call me in the USA @ 267-784-4042
    Aug 2008
    116
    Thanks Streetshooter! So doing the math, at F/4 if you focus on approximately 12.6 feet from the camera the depth of field will be from around 6.3 feet to infinity?
    I'm very visual and have a hard time making sense of word descriptions of such things. But I think I get it now.
    Senior Member Will's Avatar
    Near London
    1,054
    Another question.
    Why in that case doesn't the camera simply focus at 12' 6" when you set the focus to infinity since the lens has a maximum aperture of f4.0? Or does it in fact do that? On the manual focus shown on screen it goes from 7' then almost straight away to infinity. Maybe the infinity setting is at 12' 6"
    Jul 2008
    1,431
    17
    Will,
    That's a good question and you actually answered it to yourself...it appears that is in fact what the camera does....
    On a camera lens, you take the infinity mark and put it at the fstop you are working at...now your focused at HD....with these digicams..it's difficult to do that...the DP1 compounds the issue by only doing meters...good for you guys but usin's in the
    new Colony called the USA..we like feet...it's a foot fetish we can't translate to meters....Luckily the camera has a short lens so there is much forgivness but with the new DP2 coming out...this will be a big issue especially with a finder......
    Jul 2008
    1,431
    17
    Quote Originally Posted by andrewteee View Post
    Just take the camera outside.....make a few exposures....
    1 at infinity....
    1 at hyperfocal
    do this for each f stop and you'll get it right away......
    Senior Member fordfanjpn's Avatar
    Tokyo
    551
    Another question. When you calculate the DOF, do you use the actual focal length of the lens, i.e. 16.6mm for the DP1, or the 35mm equivalent focal length, in this case 28mm? I'm guessing that you use the actual 16.6mm focal length, but I'd like to confirm that.
    Bill
    Near London
    1,054
    Streetshooter, the latest firmware update for the DP1 enables the camera to show both metric and imperial measurements on it's screen
    Jul 2008
    1,431
    17
    Quote Originally Posted by fordfanjpn View Post
    Bill
    Bill, you have to use the actual focal length of the lens. The DOF calc gets it to 16mm not 16.6...who cares...it's close enuff...I have that program in my Iphone....
    see it online here....
    http://www.dofmaster.com/dofjs.html
    Jul 2008
    1,431
    17
    Quote Originally Posted by Will View Post
    Will, yes it does but if you look at it....
    it's accurate to 3' or about 1 meter...then it goes to some uneven spacing...
    it's actually ok on the 28mm lens but it won't work the same on the 41mm.
    I'm sure the Sigma people took that into consideration.....well, not sure but let's hope so....
    Jun 2008
    1,423
    Hello All,
    This website may be of use. http://www.dofmaster.com/dofjs.html
    You can seemingly work out depth of field for almost any camera/focal length/aperture.
    Gandolfi.
    Member gromitspapa's Avatar
    220
    Question- is focus equally sharp within a given DOF? For example, at f/4 and focused at 12.6', is an object at 6.3' as sharp as it would have been if the camera was focused on the object itself?
    Washington, DC Metro area
    67
    Based upon my experience, the answer is no -- not "equally sharp."
    But often, acceptably sharp for my kind of shooting, principally consisting of street snaps.
    I should add that I've never used the DP1, but I do at times pre-focus another compact digital, an older Canon model, to a preset distance to minimize lag. At wide angle, this has worked well. Keep in mind that the d.o.f. is extensive with all the small sensor cameras at wide angle. I think of the DP1 as a compact, but not truly a "small sensor" camera, for the reason that its sensor is ... not small.
    A number of my street snaps are here:
    http://www.flickr.com/photos/michael-s/
    Incidentally, a very accomplished N.Y. street photographer named Markus Hartel (he's in another class, and that is *not* false modesty on my part) has used a DP1 very effectively for a number of his shots, and I believe he focuses it manually. I'll look for the post in which he describes his approach to the DP1, but meantime, here (if I've done it correctly) are some of his DP1 photos:
    http://www.flickr.com/search/?q=dp1&w=77314462%40N00
    Just now located Markus' comments about the DP1. They are on this (long) thread, and you can scroll down to the post by Markus Hartel to read them:
    http://photo.net/digital-camera-forum/00PXHf
    Last edited by Michael S; 6th March 2009 at 14:38. Reason: found addtl information
    Jan 2008
    1,627
    thanks for the link to markus photos. makes me think, forget street stuff, others have done it much better! and though i've made more than a dozen trips to nyc and spent more than three years there, it doesn't have the old appeal. guess i'm getting old.
    wayne
    www.pbase.com/wwp
    Tokyo
    551
    Quote Originally Posted by Streetshooter View Post
    Thanks Don. I have a DOF app in my iPhone, but I wasn't sure about which FL to use.
    Bill
    Near London
    1,054
    This discussion is reminding me of an observation in another forum some time ago where the difference between the infinity setting and manual infinity gave slightly different focus for landscape work. The conclusion was that to get the sharpest detail in the horizon it was best to use manual focus. I think it was a GX100 or GRD2 camera being talked about. This now makes more sense if in fact the manufacturers do use the hyperfocal principal for their infinity setting.
    Some test shots would be interesting if someone has some good clear weather conditions available.
