Results 1 to 10 of 10
Thread: Creative lens flare warning
    Senior Member Will's Avatar
    Near London
    1,054
    I thought it would be fun to try some creative effects using lens flare. I got a nice image but burnt a patch on my sensor
    I'm now the Icarus of the GRD2 world. I captured to close to the sun and now my photographic wings have been damaged!
    You can see the dark spot in the top left of this image
    Lewis
    Re: Creative lens flare warning
    When did you buy this camera? I recently sent one back as it had a spot like that in the exact same place too....i don't recall ever taking pics into the sun either? Could be a generic problem?
    Subscriber Member tashley's Avatar
    Jan 2008
    South of England
    3,295
    Quote Originally Posted by Will View Post
    Thanks for the warning Will, though I do think Lewis is probably right and that this effect doesn't result from your high-flying activities!
    Tim
    Lewis
    Mine just seemed to 'develop' the spot on a night out...it's uncanny that it was in the same position also! Must be something else! I could also see it on the lcd when the camera was pointed at a white wall..
    Near London
    1,054
    Thanks for your comment Lewis, it prompted me to look through my images and I discovered that the dark area was there before I took the flare image. You were right, I just hadn't noticed it and came to the wrong conclusion. I can now send the camera back under the warrantee with a clear conscience.
    Caer
    That spot looks more like dust to me. Try taking a series of photos at different apertures - if it gets more sharply defined at smaller apertures, it's most likely dust.
    Senior Member Robert Campbell's Avatar
    Norn Iron
    1,097
    Quote Originally Posted by Caer View Post
    I also think it is a dust spot. I had a major flare a year ago, with small bright spots - but no lasting damage. I don't think that you can 'burn' out part of a sensor or pixels - not the same as hot or cold ones.
    Bertie
    Near London
    1,054
    Turns out you were right. I stopped down to F9.0 and it showed as an obvious large piece of dust. I tried shaking the camera a bit (not too hard though) and the spot has gone! Does that now make me qualified as a Recoh repair technician?
    Lewis
    I also thought mine was dust, but it was only 4 days old! How could dust get into it that quickly? It's a little worrying...
    Senior Member helenhill's Avatar
    NYC
    1,895
    16
    A Ricoh Repair Technician with Icarus Wings.......
    Cheers! Helen
