Results 1 to 13 of 13
Thread: Viewfinders on compacts.
    Member agoglanian's Avatar
    Mar 2009
    Orange County, CA
    165
    So I'm pretty positive that I will get some kind of viewfinder for my DP1. I don't mind using the screen on the D-Lux 4 because it's even better than the screen on my 1DmkIII! But, let's face it, the DP1 lcd leaves much to be desired, especially in low light. I'd rather just not use it . I'm debating however which one to get. The CV 28mm one does look promising, but I have heard it doesn't quite fit perfectly in the hot shoe? I wanted to find out if the Sigma finder is really any good? I never really see/hear much about it.
    On a side note, I really wanted to get the Leica finder for my Dlux, but at $350 I don't think I can stomach that!
    Opinons?
    Member MisiekBunnik's Avatar
    Jan 2008
    Eindhoven
    54
    Re: Viewfinders on compacts.
    I am very happy with mine, i never thought i would use it that much. Taking pictures becomes a lot more natural.
    On the lensmate site you can see the differences in brightness, but I think the sigma viewfinder is really bright enough, and a snug fit. I do not like the writing in white on top though, black would have been sufficient...
    Jan 2008
    North Vancouver, BC
    1,168
    I use the Voigtlander 28mm VF on my DP1 and yes, it is a little loose. I fix this by putting a piece of electrical tape on the bottom plate of the viewfinder. This works perfectly, and the viewfinder is fabulous with the DP1.
    Mar 2009
    Orange County, CA
    165
    nice! two completely different opinions. I wonder if either of you could post a photo of what the viewfinder looks like on each camera? I would be interested in seeing the physical size of each.
    I know the CV finder is a high eye-point, does that affect your framing at all? (I don't wear glasses personally.)
    Subscriber Member Streetshooter's Avatar
    Jul 2008
    1,431
    17
    Another vote for the Voigtlander finder....I put a piece od LCD screen protector on the bottom of the shoe and it's snug as a bug on a rug....with a 28
    Jan 2008
    North Vancouver, BC
    1,168
    Check this thread, post #10, it shows my DP1 with the VF.
    http://forum.getdpi.com/forum/showthread.php?t=5017
    CScottMcQueen
    I bought the Sigma one (If im honest, it was the cheapest @ 50) and its plenty bright enough for me. I have to agree that i don't like the white writing but a bit of black insulation tape or at a push a black sharpie would take care of it
    Excuse the poor iphone pic but it gives you a rough idea DP1 with VF-11, HA-11 and Franiec grip
    Mar 2009
    Orange County, CA
    165
    On the notion of using a piece of screen protector (or similar) on the bottom, does that make it a hassle to remove the VF? I also got the EF-140 flash with my DP1 when I bought it from a fellow photog, so I will occasionally be using that too.
    Just food for thought.
    Jan 2008
    North Vancouver, BC
    1,168
    As long as what you're putting on the bottom of the VF isn't too thick, no, it's no issue in sliding it off when needed.
    Jul 2008
    1,431
    17
    Quote Originally Posted by agoglanian View Post
    No problem, it gives just enough thickness to hold
    firm but slides off with a slight amount of pressure.
    Great finder and you can use the onboard flash too.
    Mar 2009
    Orange County, CA
    165
    I'll do some shopping around then. If I happen to come across the sigma one for a killer deal, I'll probably take that one, but otherwise I'll keep an eye out for the CV 28
    Mar 2009
    Orange County, CA
    165
    I'd also like to revive my thread and see what ideas you all have for a 24mm (or close equivalent) to use on the D-Lux 4. There are many a time (in fact almost every time I use the camera) That I would like to use a Viewfinder instead. I am just greatly concerned by the fact that Leica has the ability to charge $350 for a plastic/glass viewfinder. No matter how good the glass is, there is no escaping the fact that it is just a window to look through for APPROXIMATE framing. Something about that price greatly disturbs me.
    Anyways, has anyone found any cheaper viable alternatives? Ideally in the sub $100 range?
    SimonL
    I get a lot less camera shake since I started using the Ricoh mini-finder on my GRD-2
