Results 1 to 11 of 11
Thread: ultimate macro choice
    Senior Member nostatic's Avatar
    Jan 2008
    socal
    1,037
    From reading some threads and reviews (as well as the specs), it seems like the GR2 might be a very good choice for a take-anywhere macro shooter. I confess that most of my eye is drawn that way, toward textures and patterns, and while the D-lux3 isn't bad for macro, it doesn't totally rock either (at least in my hands). I like the idea of being able to get within 1 cm of the subject.
    Thoughts on macro use with the GR2 or is there another candidate? My SD400 has been great for macro, and even though the A620 was supposed to be better, I still preferred the SD400. The D70 and 105micro combination is great but not exactly pocketable. And it also has a very narrow dof.
    Terry's Avatar
    New York City
    6,955
    1145
    Re: ultimate macro choice
    Quote Originally Posted by nostatic View Post
    I actually have done a lot of macros with small sensor cameras. However, for most of them I used an adapter and a close-up lens. I made an adapter for a Panasonic TZ3
    I also just bought an adapter from Hong Kong for the d-lux3/lx2 which has a 52 mm thread for a close up lens. Generally I use a +4 diopter lens. I haven't tried out the new adapter yet.
    If you go to my galleries on Zenfolio:
    tbanet.zenfolio.com
    Flower Macros - Panasonic FZ8 with close up lenses either +2, +4 and +8
    April in Arizona - again FZ8
    London - Panasonic TZ3 with +4
    VladimirV
    I'd say from what I've seen the Ricoh cameras have one of the best macro modes. The GRD II is very good as is the GX-100 so I'd say it's between these two. No need for any adapters or close up lenses. The manual focus is very important to have when using macro mode and the ability to change the focus point in macro mode is a very usefull feature.
    Maggie O's Avatar
    Standards Are Down All Over
    3,064
    Man, something else to tempt me to get a GR-D II! The D-Lux 3 does gorgeous macros, but it can't get in as close...
    VladimirV
    To tempt Maggie even more, here 2 images to show why the GRD is my choice for macros and to just show off some pictures :P
    Maggie O's Avatar
    3,064
    Nice pix, Vladimir!
    (and now you've made me hungry, too.)
    hiro
    For macro I think a longer focal length is better or you will overshadow the subject. I think the GX100 at 72mm setting should give a slightly smaller field of view at 4cm than a 28mm lens will achieve at 1cm. For me that extra working distance is crucial, 1 cm is just too close for comfort.
    For reference the GX100 gives 25x19mm field of view at 72mm (4cm focus) and 29x22mm at 24mm (1cm focus).
    There is also a "zoom macro mode" which gives 17x13mm @ 1cm. I'm not sure what exactly this mode does since the handbook doesn't explain what the camera's scene modes really do, but I think it must set the zoom to the focal length which gives best magnification (since optical zoom is disabled during this mode). I know that some other cameras do this.
    Jan 2008
    socal
    1,037
    Quote Originally Posted by Maggie O View Post
    So far I haven't been able to "beat" my SD400 on macros with the D-Lux 3. Part of it may be familiarity (been shooting with the Canon for a couple of years), but the other part is I like to get up close and personal with the subjects (usually inanimate). Probably just more practice and getting to know the limits of the tool. But I have ways of working and it often is easier to find a tool that works than change the nut behind the camera...
    Senior Member Will's Avatar
    Near London
    1,054
    This is one I took with the GX100. Un cropped jpg straight out of the camera.
    Jan 2008
    socal
    1,037
    cool. Was that at 72mm or do you have ninja fly skillz?
    Near London
    1,054
    72mm and ninja fly skills I have some even closer up but the composition isn't so good.
