Results 1 to 5 of 5
Thread: Sigma DP2 SD card speed
    Senior Member Tim's Avatar
    Jun 2008
    Adelaide, SA
    1,040
    Well, I've taken the plunge ordered a DP2 and am awaiting delivery. While I wait, I got to thinking I'll need another SD card or two and so considered what speed I will need.
    Sure the extra speed cards are cheap enough but just wondering, is there any advantage spending the extra for a class 4 or class 6 card for the DP2 - will it improve write performance on this camera?
    Has anyone done or seen any tests with card speed and the DP2 write speed?
    Tim
    Subscriber Member Streetshooter's Avatar
    Jul 2008
    1,431
    17
    Re: Sigma DP2 SD card speed
    Definately use a Class 6. I use Lexar Pro because I had a very bad
    experience with sanscrap.....
    There is a noticable difference in write speed.
    Don
    Senior Member Don Ellis's Avatar
    May 2009
    Hong Kong
    556
    Remember, too, that not all Class 6 cards are created equal. Class 6 denotes a minimum speed for that classification, but many Class 6 cards go much faster. I know.
    Don
    Jun 2008
    Adelaide, SA
    1,040
    The Ricoh forum guys tested a bunch of class 6 cards and on the GRD IIs the Panasonic class 6 edged out the rest but they are quite a bit more $$. I'll check the Lexar Pro prices, thanks for that.
    Jul 2008
    1,431
    17
    Another card that's really fast is....
    Delkin Devices Film Pro...it's a class 6 but writes at about 250x instead of the normal 133x. With the DP1 or 2, ya need all the speed you can get....
