Results 1 to 9 of 9
Thread: Banding in GX100
    dkogan
    Banding in GX100
    Hi, all.
    I'm seeing an issue with my GX100, and would like to know if others see it also and what can be done about it.
    If I set the camera to a very long exposure time (>1min), and photograph a scene that has thin, vertical-ish features I get VERY pronounced horizontal banding in these features. This is very reproducible and very annoying since it takes the greatness out of great pictures. One example of a scene where this happens is a night sky with star trails. Some of the trails get the banding. Happens in both raw and jpg.
    I can post examples if yall want.
    Anybody seen this?
    dkogan
    Re: Banding in GX100
    Here's an example. Below is a crop from a scene with a starry sky.
    Full direct-from-camera image is at
    http://www.cds.caltech.edu/~dkogan/banding.jpg
    549
    It could be that this is due to the rotation of the earth. I looked up some discussion about star trails and it seems they become noticeable at around 20 seconds at the wide end, and at shorter exposures at the long end.
    Hardly a camera fault if this is the case.
    dkogan
    The streaking is certainly due to the rotation of the earth, but the black horizontal bands in some of the streaks are a camera fault.
    549
    Sorry I missed the point here. See what you mean. No clue.
    Member kai.e.g.'s Avatar
    Jan 2008
    Friuli-Venezia-Giulia, Italy
    150
    It's odd that these dark bands are not evident at all outside the stars themselves. Whenever I've seen banding in digital cameras, its usually more noticeable in the darker areas. It's almost like a tiny moire pattern here. The lines don't even seem entirely parallel. Is this crop processed from a RAW file, by the way?
    The full-size image you linked to is indeed beautiful, by the way.
    It's also possible that an evil mastermind, either local or alien, was speeding up/slowing down the earth's rotation in a rhythmic fashion that night, just for fun. This used to happen all the time in the 1950's.
    Lili's Avatar
    2,527
    Before I sent my K100D in for sensor issues, hot pixels mainly, I stated seeing black banding like streaks from bright lights in dark areas.
    Nothing like this tho
    Senior Member Per Ofverbeck's Avatar
    Feb 2008
    503
    5
    Quote Originally Posted by dkogan View Post
    Well, it looks exceptionally regular, indeed, almost like a stroboscope effect. If we reject the hypothesis that all the stars run on AC current as being too unlikely, the periodicity must be in the camera´s electronics instead.
    Have you made any attempt at determining the frequency of the banding (easy if you know the xposure time of course); you say it is very reproducible?
    Could it be some kind of noise reduction that makes correction at regular intervals during exposure instead of after the exposure is finished? Possibly far-fetched, but the phenomenon looks distinctly non-random.
    dkogan
    Thanks for the replies.
    It seems that this happens even with stationary objects. Full (but not very interesting) image at
    http://www.cds.caltech.edu/~dkogan/bandingnomotion.jpg
    Has nobody really seen this before? I'm finding it hard NOT to see this effect with long exposures.
