DP2 cyan troubles
andrewteee
Good as my Sigma DP2 is, it has cyan troubles. Sean Reid identified this issue, but in his analysis it is primarily in the corners and at wider apertures. However, with my DP2 the cyan impact runs across the entire image and at all apertures. The appearance of the cyan tint is consistent. Is this common, or should I consider that my particular DP2 is not working correctly? Here are two samples. TIA for any feedback.
