Results 1 to 5 of 5
Thread: swore i'd never do it again
    Jan 2008
    1,627
    buy a backup. i've done it five or six times, then switched my camera passion! but i've done it, a dp1 from keh, outfitted now with the franiec grip and voigt vf.
    here are some tests, done with the sigma flash for fill-in. i do think the flash brings out even more detail. it has manual and ttl. you can set the camera on manual and adjust for different levels of flash effect. also it shoots cleanly over the the filter/hood attachment, which the on-camera flash will not do.
    wayne
    www.pbase.com/wwp
    Senior Member otumay's Avatar
    Mar 2008
    Istanbul, Turkey
    1,690
    2
    Re: swore i'd never do it again
    Beautifully executed, Wayne. I think DP-1's flash works wonders and SPP gives the correct white balance (which sadly, was never the case with Sigma SD14).
    Best,
    Osman
    Jan 2008
    1,627
    thanks, osman. yes, the wb set on flash and the flash on ttl. (converted from raw). interesting about the sd14. almost bought one when they were cheap on amazon - they've doubled in price - and i found reading user reviews they felt the dp1 better iq, perhaps because of the specific lens/sensor fit. interesting what they do next. leica coming out with a bunch of new stuff on sept. 9.
    wayne
    www.pbase.com/wwp
    Jan 2008
    1,627
    ps. a few more with same settings. to show possibilities of color and detail.
    Senior Member Tim's Avatar
    Jun 2008
    Adelaide, SA
    1,040
    Quote Originally Posted by smokysun View Post
    I suspect also that the magic from the DP1/2 is due the the specific lens and sensor fit. Its just one of those things that seems to work well.
