Results 1 to 3 of 3
Thread: Mirex tilt/shift
    Oct 2009
    123
    Mirex tilt/shift
    I should be receiving my Mirex adapter next week (review by Pete Ganzel http://www.dyxum.com/dforum/mirex-m6...opic51123.html posted at Dyxum) for use with my a850.
    I've also purchased the Mamiya 645 55mm f/2.8, the 80mm f/1.9, and the 120mm f/4 macro. I've read mixed reports on the Mamiya 35mm f/3.5. Most report good center resolution, but extreme softness in the corners.
    In the opinion of folks who have used the Mamiya 35mm, is the lens worth acquiring? I'm looking to use the other lenses in portrait mode for multi-frame, stitched images. It would be nice to also have a moderately wide lens for single frame images, but the edge softness reported by many is putting me off, especially as I plan to tilt the lens and use more of the glass than is normal for a MF lens on a 35mm sensor.
    Regards,
    Graham
    Oct 2009
    123
    Re: Mirex tilt/shift
    I found this thread http://www.fredmiranda.com/forum/topic/727356 discussing various Mamiya lenses on the Mirex T/S.
    Graham
    Aug 2008
    Bruce Peninsula, Canada
    2,534
    184
    I have the 35 mm and use it regularly. At f11 it is a fine lens; at larger apertures it does show corner softness.
    Bill
