Results 1 to 11 of 11
Thread: NEX flash connection
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    Question NEX flash connection
    Has anyone managed make a cable connection (extension) for the NEX flash slot?
    Also, is there a screw in flash cold shoe available?
    TIA!
    (PS: Except for a couple of test snaps, I have not used the supplied peanut flash.)
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    Re: NEX flash connection
    Does anyone use this flash at all or is it just like the wide/fish converters that Sony made for the NEX lenses?
    Los Angeles, California, USA
    1,965
    I actually haven't taken it out of the box since the camera arrived.
    May 2010
    156
    i took it out of the box once and used it once to test that it did in fact flash.
    it did.
    Jan 2008
    North Vancouver, BC
    1,168
    Vivek,
    I've used it a couple of times for indoors shooting. It's reach is just a few feet but it seems to work well exposure-wise. You are able to adjust the flash EV for balancing (runs a bit hot for my taste). It's probably usable as a daylight fill flash. As a rule, I very rarely use flash, so the NEXs' low light performance really thrills me.
    I'm really hoping for an EVF to use with that port.
    Jun 2009
    Minnesota, USA
    337
    Interestingly, the NEX camcorder comes with an A-mount hotshoe (at least visually that is how it looks), in addition to a coldshoe. So that means future more "serious" models will come with an A-mount hotshoe.
    A900 with a few lenses, flashes etc.
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    Surely one does not need this many connections if it is only for a flash and a stereo mic?!
    Untitled by Vivek Iyer, on Flickr
    NEX Peanut flash' connector
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    I opened up the peanut flash (pry open the side plastic panels. Underneath each side, there are two screws.).
    Sony went crazy with the wiring. There are at least 5-7 electrical connections leading to the plug. A bit more complicated than I thought.
    Still, a lot less connections needed for the flash than the 14pins in the connector.
    1,965
    Intereting, Vivek. Surely we'll see some data port accessories that are actually useful, right Sony?
    Member LizaWitz's Avatar
    Feb 2009
    112
    Sony really needs to make a GPS receiver for that port.
    Senior Member hot's Avatar
    May 2009
    Austria
    2,169
    ... or a Cola bottle holder .. !
