Results 1 to 5 of 5
Thread: LINUX-based source code for Sony cameras
    Senior Member hot's Avatar
    May 2009
    Austria
    2,170
    Member LizaWitz's Avatar
    Feb 2009
    112
    Re: LINUX-based source code for Sony cameras
    Looks interesting, should at least give a leg up to anyone who wants to hack the firmware (To give us 1080p movie mode... I hope.)
    Los Angeles, California, USA
    1,965
    The NEX-5 actually records at 1080p 30fps, but, because of the AVHCD codec, it puts it in a 60i wrapper. Once inside your NLE, it is treated as 30p.
    Jun 2009
    Minnesota, USA
    337
    The AVCHD spec is wide enough to accomodate 1080 30P. Don't know why Sony is placing it into a 60i wrapper. They do the same in case of the A55 too.
    Sure, 1080 60P will not fit inside the 24mbps bandwidth of the AVCHD Spec but 30P should not have any problem at all.
    A900 with a few lenses, flashes etc.
    Feb 2009
    112
    Thanks Douglas, you're right. I didn't say what I meant to say, which is I'd like the NEX-5 to be hacked to record 1920x1080p in MP4 format (instead of 1440) at around 20 or 30Mbps.
    roweraay- I think the reason for the fondness of 60i wrappers is that they can use this mode for recording and use the same hardware/software for outputting to TVs. Maybe older tvs can handle 60i but not 30p? (considering most people buying the camera are likely consumers...)
