Results 1 to 9 of 9
Thread: Are the Axx cameras as easy to mf as the nex
    218
    2
    I know some on here have both an A33/A55 and a nex camera. I really like the manual focus on the nex. Is it as good on the Axx cameras? I'm interested in both the evf and lcd and how they compare.
    thanks,
    Mike
    jonoslack's Avatar
    East Anglia & Cornwall (UK)
    11,778
    Re: Are the Axx cameras as easy to mf as the nex
    Quote Originally Posted by docmaas View Post
    thanks,
    Mike
    Hi Mike
    I haven't tried - I think they probably are, but it's not really the same deal, you can't mount all those nice old M mount lenses on the 33/55, and the autofocus works well and fast . . .
    You can easily zoom in on both EVF and LCD though.
    Just this guy you know
    Mar 2009
    103
    thanks,
    Mike
    First let's talk about manual focusing. Qualifying statement: I don't have the Axx yet so take my opinion with a grain of salt.
    1) I don't consider the manual focus on the NEX that good. I have to hold the camera away from me, look at the screen and focus. Most of the time that is not good enough so I have to hit the focus assist button to zoom in. By then the image is swimming all over the place.
    So finally I bought a loupe with a hood from Hoodman and that solved my manual focus problem on the NEX. Yes it is bigger but at least I can use my MF lenses.
    2) I use the EVF on my Panasonic G1. That should be much closer to use in a manual focus situation as the Axx because I am looking through a viewfinder. Albeit the image is still electronic. However I loved the way the manual focus comes into view with my G1 so I assume that is going to be the case with the Axx.
    3) The G1 and the NEX has a shorter lens register distance so you can fit just about any lens on top with an adapter. The Axx is a normal digital camera with a standard Sony alpha lens register. So you are limited to which manual focus lens you may fit on it.
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,610
    21
    Quote Originally Posted by HansenTsang View Post
    Nailed it. It is just another DSLR. Only here, the mirror does not move while shooting.
    Nov 2008
    3,848
    Except with adapted lenses, such as Leica R lenses, it should be able to nail focus more accurately than the same adapted lens on a DSLR -- since focusing is directly off the sensor.
    Terry's Avatar
    New York City
    6,955
    1145
    I expect it to be doubly easy with the A55 because the focus box also lights up in green for confirmation. Who makes a Leica R to alpha adapter?
    Nov 2008
    3,848
    218
    2
    There is also an ebay seller of a good product but I don't have the name at hand. I've posted it here before and on dpreview as well.
    Mike
    218
    2
    to all. thanks for your input. My eventual goal is probably a sigma sd1, once it comes out providing it is as good as promised. Unfortunately it won't have live view in the first generation from what I understand so I may be forced to manual lenses only or maybe an "m" screen equivalent.
    On another note. I continue to see the red dot pool party in the lcd when using manual focus on the nex in low light and at small apertures. It will be a limitation for some. Sony probably needs to work on getting a less noisy screen at low light levels if that is possible.
    Mike
