Results 1 to 6 of 6
Thread: NEX5 with Leica 35mm F2 ASPH
    Aug 2009
    46
    Hi all,
    I am just practicing taking pictures with my NEX5 and Leica M Lens.. It is quite different in focusing when I hold the camera in front of my chest but not on my eye level.. It is not easy to get the focusing right particularly in shooting with my 90mm Tele-Elamert F2.8. Hand shaking is the main challeng. I shoot with S mode and most of the time I will use 1/125 second or higer to avoid shaking. Of course, the camera will not know what aperture I am using, I rely on the auto ISO to let the camera to find the proper ISO setting to adept with the aperture and shutter speed that I choose. I am not sure if some of you here may use the same approach ? or you have different tricks which can archive better exposure than my approach ?
    Here are a few pictures from my NEX5 and 35mm F2 ASPH. Thanks !
    Jun 2009
    Canada
    17
    Re: NEX5 with Leica 35mm F2 ASPH
    Results look very good! Is that old house for display or a real home? Seems too quaint to be true!
    I use A mode only myself, but I can certainly understand using T mode in the same way given the circumstance. Though the NEX seem to be very good at noise handling and with the quality of noise handling software these days, it seems like your system is doing a fine job. Using A mode, the camera will react by adjusting the shutter and ISO to match whatever light is passing via the lens. In normal conditions the shutter will probably be much faster than would be of concern for hand shake. For lower light, you can always force a higher ISO manually to compensate.
    Kelly.
    Los Angeles, California, USA
    1,965
    I usually just use M mode with manual lenses, and that way I can quickly adjust shutter speed by looking at the histogram.
    Check out the Clearviewer, if you want a very easy way to manual focus. Works very well.
    Aug 2009
    724
    Beautiful shots! Carousel horse and gentleman are my favorites.
    Aug 2009
    46
    Thanks. These pictures were taken in the Burnaby Museum in BC, Canada. The log house is for show only. Will upload more pictures later.
    Aug 2009
    46
    More pictures with NEX5 and 35mm Summicron, 90mm Tele-Elmarit and VC 15mm F4.5.
    Please see the following links:
    http://www.flickr.com/photos/4199224...7626354990352/
