Results 1 to 4 of 4
Thread: Minolta bayonet mount = MD/MC?
    Senior Member Rawfa's Avatar
    Nov 2008
    Rio de Janeiro
    2,393
    I'm not sure if this is where I should be posting this but here it goes...Is the Minolta MD MC mount the same as the minolta bayonet mount? I have a couple of good offers on some zooms and but I need to know if these mounts are the same.
    cheers
    Rafa
    kgior
    Re: Minolta bayonet mount = MD/MC?
    Bayonet mounts are everything that came after screw mount lenses.
    If you are asking only about the compatibility prior to Maxxum I won't be much help, I thought that there was only one bayonet mount and probably one screw mount before but I am not 100% sure.
    When Minolta introduced the Maxxum 7000 it changed to a new mount with the auto focus feature. That new mount is the same one that Sony now uses on its Alpha cameras. It has evolved over the years as far as electronic contacts are concerned, therefore not all of the current controls are 100% supported with the older Maxxum AF lenses (ADI flash, SSM focusing).
    Without some kind of adapter (I believe that they all include an optical lens to correct for focusing) this AF mount is not interchangeable with the older manual focus lenses.
    Hope this helps some.
    Ken
    Jul 2010
    495
    http://en.wikipedia.org/wiki/Minolta_SR_mount
    sr, mc, md, x-600 are all compatible.
    Nov 2008
    Rio de Janeiro
    2,393
    Thanks, guys.
