Results 1 to 3 of 3
Thread: need a ring flash for a a900
    Subscriber Member mwalker's Avatar
    Kentucky
    924
    74
    Any recommendations for a ring flash for a a900?
    Mike
    website under construction
    Apr 2008
    210
    14
    Re: need a ring flash for a a900
    Mike, I recently acquired a Metz Mecablitz 15 MS-1. TTL control can be used with Sony, Pentax, Olympus 4/3, Nikon, and Canon systems as this is a universal unit and also has a slave learning function. You can also connect via PC sync cable. For photographers with multiple systems or to future-proof your investment if you decide to switch, it doesn't get much better. - Christopher
    Jun 2011
    Cumbria
    114
    I also suggest the Metz 15 MS1, I have one and find it very good. You will need a small flash like the HVL-F20m to trigger it.
    There is also the Sigma EM 140 as well as the Marumi DRF14 both of which are available in Sony fittings. You may need to order them as the Nikon/Canon versions are more readily available.
