Results 1 to 11 of 11
Thread: Non ZA Zeiss on A850/A900?
    Subscriber Member kit laughlin's Avatar
    Two suitcases and the latest MBA
    1,334
    What are the options for adapting ZF or other mount lenses to the big Sonys?
    My favourite lens on the A850 is the ZA 85/1.4, but I want ultra-wide, too (especially since selling the 14-24/2.8, along with all the other Nikkors when I made the move to Sony).
    Manual focus would not be a hindrance for UWA/WA (but I love AF on the 85).
    Looking forward to hearing from you!
    Los Angeles, California, USA
    1,965
    Re: Non ZA Zeiss on A850/A900?
    297
    Leica Elmarit 19/2.8 version 2 with Leitax mount.
    Alan
    Feb 2009
    Bangkok
    1,470
    All ZF lenses can be adapted to the alpha mount via a mount replacement from leitax. However I think the ZA 24 is an excellent lens with a beautiful rendering, but if you want wider, then leitax is the only way.
    Senior Member pegelli's Avatar
    Dec 2010
    Belgium
    2,128
    All ZS lenses can be mounted with a standard M42 to A-mount adapter. With a chipped adapter (with the actual FL programmed in) you'll get correct anti-shake as well as focus confirm. Not the most important aspects of a WA, but an advantage anyway.
    Feb 2009
    Bangkok
    1,470
    Btw the ZA 16-35 is absolutely amazing. You just have to be careful with focusing. Due to the pronounced W shaped curvature, focus/recompose doesn't work well. I used it with excellent results by composing first then focusing via one of the peripheral points, and some manual fine tuning if necessary. It can produce a lot of 3D, better than many primes.
    Feb 2009
    Bangkok
    1,470
    Quote Originally Posted by pegelli View Post
    ZS lenses are now discontinued (but still available in stocks). There are only 3 lenses: 50/1.4, 35/2, and 25/2.8.
    1,334
    Thanks to everyone—I may just have to buy that 16–35!
    I have read all the reviews of the ZF lenses on Lloyd's paid site, and 18.5 is as wide as Zeiss go with the ZFs, so for my purposes, even though it means a zoom, the 16–35 is looking good. Thanks to everyone who responded. KL
    Feb 2009
    Bangkok
    1,470
    Kit, if you decide to get the 16-35, make sure to check it well for decentering. It is a very complex design, and assembly defects are not uncommon. My first copy suffered from this, but it was promptly replaced by Sony.
    1,334
    Thanks Edward; I definitely will. Is there a definitive test for this flaw? Cheers, KL
    Feb 2009
    Bangkok
    1,470
    The simplest test is the tilted horizon. You take a shot wide open at infinity, with the camera tilted at 45 degrees so that the horizon passes through the corners. You do the same while tilting the camera the other way, so that you basically get horizon shots of all 4 corners. Then you compare the corners for uneven sharpness, CA and vignetting. It only takes a minute and it's very easy to spot any defects.
    PS: don't get too critical about it. Most lenses will show some degree of decentering. If it isn't too obvious then it should be ok. I almost became nuts comparing corners of my various lenses, the perfectly assembled lens doesn't exist.
