Results 1 to 11 of 11
Thread: 850 Flash Sync problem
    Jjcra
    I just got my 850. I am having trouble syncing my strobes or flash, I select a shutter of 250 no flash. I end up at 40 and it works every time at 80 it is hit and miss and nothing at higher speeds. What am I doing wrong?
    Aug 2010
    271
    Re: 850 Flash Sync problem
    What strobes are you using? How are you triggering them? What camera mode are you using?
    SONY A900
    Always outnumbered, never outgunned.
    My Site|Facebook Fanpage|
    Jjcra
    Oh sorry I guess that would be good to put in. I am shooting manual, Strobes are alien bees triggered wireless thru a hot shoe adapter and off shelf triggers.
    I have used this many times on the A700 without a problem. I also thought the triggers or adapter might be the problem, but that would not explain the firing at 1/40. At least in my reasoning.
    Aug 2010
    271
    Check your shoe connections for good contact. Did you sent the A850 to manual flash mode in the menu? Do the triggers still work on the A700? Will the triggers fire other flashes and sync with the 850?
    SONY A900
    Jjcra
    Thanks Lonnie for getting back to me. Manual flash mode in menu? All I see is pre-TTL or ADI. When I get home tonight I am going to try and fire with a sync cable to strobe and my lash on camera to ensure 1/200 as well as using triggers on 700
    Aug 2010
    271
    Check to see if you have a "flash mode" menu option on the same page in the menu where you already were (record menu, page 2.) It should be right above the "flash control" menu item that selects pre-ttl or adi that you already found. What's that set to? You should have options for Autoflash, Fill flash, rear-sync and wireless. Try Autoflash or fill flash.
    SONY A900
    Jjcra
    Will do. Thank You
    Feb 2009
    Bangkok
    1,470
    I always use my A900 at 1/60 with studio strobes. I found out at over 1/90 they do not synchronize well and I have missing parts of the photos, but they always fire.
    kgior
    My a900 syncs just fine at 1/250 with my normans and a wireless transmitter.
    Remember to turn off sss.
    Ken
    Member Quino Terceño's Avatar
    Exile
    47
    I am getting 1/250 with skyports on my RX600s and 1/200 on the 58s triggered with PWII.
    Jjcra
    Well it ended up being one of the receivers, I honestly never would have guessed that since it worked at 1/80 without any trouble. Anyway lesson learned. Thank you everyone for your help.
