Results 1 to 5 of 5
Thread: Hawks LEICA-M L-M to SONY NEX E-mount MACRO TUBE HELICOID Available now!
    Oct 2008
    Seattle, WA
    5,672
    Hawks just sent me an email saying that they had some available on US Ebay: 10 of them (now 9). After seeing Jono's shots this is a "must-have" for the Nex - Leica M combination.
    Cheers, Matt
    http://mdriscoll.zenfolio.com
    Sep 2010
    San Jose
    269
    Re: Hawks LEICA-M L-M to SONY NEX E-mount MACRO TUBE HELICOID Available now!
    Thanks for the heads up Matt, ordered one.
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,601
    21
    I am not sure there was another thread on this adapter (I searched for 2 days) but rather than starting a new thread, I will ad a few things here.
    I have two of these now bought from John (JLM) and Jonas here. Possibly V1 and V2.
    I took out all the screws, cleaned the threads and put them back with new loctite. The helicoid was also washed off to remove the original grease and regreased with a slightly stronger version.
    I had to do this to minimize the wobble. Now, there is still a slight wobble and it does affect the sharpness. In some cases where the lens is too sharp for the NEX, this is a blessing in disguise. No moire.
    144
    Hi Vivek
    Thanks for your post.
    I thought that my lens was moving but now I see that the helicoid has a very slight wabble.
    I will try your remedy. What new grease (synthetic?) did you use? Is it quite stable at higher summer temperatures and still fluid enough at lower temperatures ( -20 C)?
    I always appreciate your technical and exotic lens input.
    Paul
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,601
    21
    Paul, This one works fine (although there are many specialized ones available):
    https://www.tamiyausa.com/product/it...oduct-id=87099
    (if you look around, you could find the same for less)
    You only need to apply the tiniest amount.
