Results 1 to 7 of 7
Thread: where to send my a900 for repair?
    Mar 2011
    209
    Nothing serious. The rear dial is not functioning properly. It's registering more clicks than actually rotated. For instance, when i look thru the pictures and rotate the rear dial only a few clicks the pictures would scroll endlessly. Same thing with changing the aperture. This doesnt happen all the time.
    I was wondering if i should send this to sony or get it fixed at a local camera shop because im not the original owner and i dont have the original receipt. Would sony still still fix it?
    thanks.
    Aug 2008
    Bruce Peninsula, Canada
    2,535
    184
    Re: where to send my a900 for repair?
    Not knowing where you live makes this difficult to answer. Personally I have found Sony in Toronto to be very good, if a little slow, for both warranty and non-warranty work.
    Bill
    Mar 2011
    209
    sorry. located in NJ, U.S
    Oct 2009
    123
    You can easily fix your skipping control wheel problem yourself. Get a can of CRC QD Electronic cleaner (http://www.amazon.com/CRC-05101-QD-E...=pd_sim_auto_1). The amazon link is for illustrative purposes, you should be able to purchase a can locally at an auto parts store (I know the O'Reilly auto parts chain carry this). You can find similar products (electronic contact cleaner) from various manufacturers, and they should work as well. If you're using a different brand, make sure it's "quick dry" and "plastic safe".
    Attach the included tube to the nozzle, hold the camera inverted, and spray a burst on the top and bottom of the wheel. Work the wheel for 20-30 seconds. Your problem should be corrected. If not, repeat.
    Graham
    Aug 2008
    2,535
    184
    Jaehoppa, please let us all know if Graham's solution (no pun intended!) works!
    Never know when it might be one of us.
    Bill
    Mar 2011
    209
    will do! hopefully this will work!
    thanks for your tip graham!
    Aug 2010
    271
    FWIW this was a very common problem with the A700...
    SONY A900
    Always outnumbered, never outgunned.
    My Site|Facebook Fanpage|
