Results 1 to 7 of 7
Thread: Nex 7 with Zeiss 15mm 2.8 ZM
    Senior Member ryc's Avatar
    Feb 2009
    Or-Y-Gun
    548
    I have been reading a lot about the NEX not handling wides very well. I am very new to the NEX world but have not had any issues with wides that I can think of. The widest lens I have is the 15mm ZM and hereis a sample of what the NEX-7 did with it. Am I missing something here?
    To see a larger image just click on the image in this link
    justnex.com - justnex.com Gallery Photo Nr: 26383
    Senior Subscriber Member Mike Hatam's Avatar
    Los Gatos, CA
    853
    236
    Re: Nex 7 with Zeiss 15mm 2.8 ZM
    JT - that's a wonderful lens. If you look closely at your image above, you'll notice color shifting in the corners (magenta cast in the corners of the images). This is due to the nature of the NEX-7 sensor and the extreme angle the light takes when it hits the corners of the sensor (it is diffracted by the glass/lenses that cover the sensor).
    This is easily fixable by processing your images through a tool called "cornerfix" (export to DNG, run cornerfix on the DNG files, then edit your DNGs as usual in LightRoom).
    If the color shift doesn't bother you, then don't worry about it - just shoot away and be happy
    You can also convert to B&W, which eliminates this issue.
    Mike Hatam
    Sony A99, RX1, RX100
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,597
    21
    You have had this lens since your M8 days, right? Taking care of the magenta madness should be a piece of cake for you.
    Feb 2009
    Or-Y-Gun
    548
    Great memory. yes. used it on the M8 quite a bit.
    Apr 2008
    1,446
    wow big glass for nex! for me the cv 15 f4.5 seems to work well with nex 5n with no noticable color cast, but guess thats because its not a nex 7
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,597
    21
    Quote Originally Posted by ryc View Post
    Two factors:
    1. You were one of the first ones to show samples from the 15/2.8 that I know.
    2. The samples were really striking (there were a few shots from a bar if I am not mistaken).
    Feb 2009
    Or-Y-Gun
    548
    You mean these ?
