Results 1 to 14 of 14
Thread: Hawk's NEX–M adapter suggestion
    Subscriber Member kit laughlin's Avatar
    Two suitcases and the latest MBA
    1,334
    This is a wonderful, used-every-day addition to the NEX users of M-mount lenses—but it needs a detent (click stop) at the standard (non close-up end) position.
    This would turn a great bit of kit into a supreme one. I find that while walking around, I tend to bump the Hawk's adapter off the standard position (which I reset it to after using) which can waste valuable time, especially in the portrait orientation.
    Apart from that, it lives on the NEX-7. What do others think?
    Apr 2008
    1,446
    Re: Hawk's NEX–M adapter suggestion
    agreed maybe while hes at it why not add some tilt axis onto the adapter! my helicoid adapter seems to have enough damping to not move too easily.
    330
    130
    Good idea Kit - I really like mine but your addition would be welcome. Not so sure about the title feature unless that was a separate adapter
    1,334
    Shac; not sure what you mean when you say 'title feature'—can you elaborate? TIA, kl
    Apr 2008
    1,446
    think he meant "tilt" feature, like the ones found in some adapters than can add tilt or shift to a lens
    1,334
    Ah: make perfect sense (especially with the image circle of the alt. lenses we are all using); thanks
    Apr 2011
    61
    Agreed. Actually a simple lock and push release at either extreme would be good enough. I also notice tend to twist the adaptor all the time.
    1,334
    I have sent a message with a link to the manufacturer; let's see what he comes back with.
    Member JimBuchanan's Avatar
    Sep 2008
    110
    Quote Originally Posted by kit laughlin View Post
    Without trying it, I am not sure I see an advantage to it, and it could introduce tolerances that would affect the hard stop infinity setting of a lens. I can see the desire to reduce the minimum focus distance of a lens, but catering to camera rangefinders aside, lenses are usually designed for a particular minimum focus distance.
    1,334
    Jim, there have been many posts on this; the rendering is wonderful, and every lens I have used with it is thereby able to focus much closer than normal, and infinity works on all of them, too. It's a really well-made device. I use mine daily, but I like a close view of things, too.
    330
    130
    +1 - the Hawk's works just fine including infinity with every Leica/CV lens' I have (15, 25, 34 'cron V1 V 45, 0 lx, 50 'cron DR & V4, 90 elmarit M, 90 AA)
    Kit - your idea of the detent sounds a good one IMO
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,604
    21
    I have Hawk's helicoids (fabulously made I might add) but not this one. In addition to the click stops, I would like a closed helicoid.
    Just last sunday I was shooting a few snaps in the local dunes. The NEX-C3 + LTM adapter + a thin extension +the CV 15 lens fell down on the sand with a soft thud. Just blew off the dry sand and it was back to business.
    Can not expect that with this adapter.
    Apr 2008
    1,446
    vivek, think though with any lens, falling into sand will not be good for it. This would be especially so if you dropped the rear end of the 15mm into the sand without a rear cap. The helicoid of the main focus mech for the cv 15mm is exposed, just as much as the lm-nex helicoid is.
    I get what you mean though when the lm-nex helicoid is fully extended in macro position, there is a possibility that dust or sand could migrate into the helicoid mech even when lens mounted.
    Sep 2008
    110
    Jim, there have been many posts on this; It's a really well-made device. I use mine daily, but I like a close view of things, too.
    I will definitely vouch for the Hawk's factory quality. I have a NEX mount helicoid with 7mm travel, made by Hawk. It is very well made and very smooth. I am currently trying to mount a Russian Jupiter Sonnar 50/1.5 into it.
    The 7mm travel is way more than the Sonnar needs, so I might get a little closer action as well.
