Results 1 to 4 of 4
Thread: tripod head with the NEX 5N
    Dec 2010
    528
    So I have a problem with mounting my NEX 5N with the metabones adapter for Contax G lenses onto my tripod head. The adapter extends below the level of the camera body (of course in front of the body) and this interferes with the kind of quick release mounting plate the head uses. Has anyone run into this and if so can you suggest an option or a particular release plate and head that worked for you.
    Thanks,
    John
    Apr 2008
    1,446
    Re: tripod head with the NEX 5N
    maybe the L bracket mount would help??
    Oct 2010
    North Carolina
    431
    I don't know which plate you have but many are common "Arca Swiss" type and will work with other vendor's head. I use the Really Right Stuff camera plate for the Nex5N and it works fine with both my Kirk & Fiesol ball heads. The plate does not interfere with my Contax G lenses on Metabones adapters. Really Right Stuff - Item Listing
    Dec 2010
    528
    Thanks mazor and turbines. Good suggestions that pointed me in the right direction.
    Thanks again,
    John
