Results 1 to 7 of 7
Thread: Tip for using wireless triggers with the 7?
    Senior Member Show Performance's Avatar
    Dec 2009
    Austin, TX
    851
    5
    One downside to the EVF is that when shooting in manual mode stopped down in a dark scene, you loose the ability to see your subject in the EVF or on the LCD.
    This situation is rectified when popping the built-in flash as there is a small mechanical switch in the flash housing that when released, tells the camera to "gain-up" the screens.
    Problem is, when using the FA-HS1AM hotshoe adapter (the only one that works for me) with a wireless trigger, the flash cannot be released out of the housing. BUT, I found that with a little upwards gentle pressure on the left rear of the flash you can get it to move up and stick far enough so that the switch is released and the screens gain-up. And since, the flash is still pointed down in the housing, you don't need to cover it up.
    This will work for me but If anyone knows of another less kludgy solution, please let us know. Really wish Sony would make this a menu option.
    Thanks,
    Chad
    Disregard - per posts from Mazor and Doug, I'm a dumb#$% and should have read the manual. Turning off Live View Display setting effect does the trick. Thanks guys...
    Apr 2008
    1,446
    Re: Tip for using wireless triggers with the 7?
    nice find,
    but doing prolong shooting with the flash firing into confined space would possibly cause overheating?
    Also but using the setting effect to off ,does that not keep the evf bright in low light situations?
    Los Angeles, California, USA
    1,965
    There is a menu setting for both the 5N and 7.
    SETUP--> Live View Display--> Setting Effect Off
    Dec 2009
    Austin, TX
    851
    5
    Thanks Douglas and Mazor, I knew someone here would have read the manual for me
    1,965
    Ha! I've never opened the manual, but I usually do scroll through every menu item on a new camera and see what it does...except for some jpeg features.
    Senior Member hot's Avatar
    May 2009
    Austria
    2,170
    I read a camera's manual for 3 to 1 month, THEN I BUY THE CAMERA!
    Dec 2009
    Austin, TX
    851
    5
    Quote Originally Posted by hot View Post
    GOOD FOR YOU!
