Results 1 to 7 of 7
Thread: Strange but true- NEX
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    Exclamation Strange but true- NEX
    The NEX-5N' shutter unit has 3 holes (for screws) for it to be secured to the plastic frame (body) but there is literally no room in the frame for the screws and is held by just a single screw!
    NEX-7 has that few mm on top and the shutter unit (not different than the ones in 5N') is secured by 3 screws to the thin plastic frame.
    Apr 2008
    1,446
    Re: Strange but true- NEX
    haha you saying the 5n sensor may come loose eventually with a single screw attachment and if this screw loostens the 5n sensor focal plane may change or maybe tilt even lol. free tilte sensor design!
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    The sensor is secured with 4 screws. It is the shutter assembly (probably the heaviest unit in the whole cam* and the only one that has moving parts) that is put there with a single screw!
    * or it could be the mount that is heavier.
    dekie
    In the NEX 3 the shutter assembly is secured with three (copper colored) screws:
    Undressing a Sony NEX Camera
    dekie
    And here you can see that the NEX 5N shutter assembly is secured with only one screw.
    Practical Nature Photography: Disassembly of the Sony NEX-5N digital camera
    Apr 2012
    49
    Crikey I hope my Nex-5n holds up when I take it to Burma. I wonder how much it would cost to repair it, if such a problem developed?
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    Since I have a broken NEX-5N (cracked body from a fall and the shutter mechanism is beyond repair), I could examine it as I please.
    Interestingly, the crack occurred in the bottom front portion of the body. No plastic parts were affected.
    I was curious. The front portion of the NEX-5N looks like plastic, extremely light weight but scratches like metal.
    It is just an astonishing material that I have not encountered before. It appears to be cast aluminum foam. Aluminum metal with air content somewhere between 70 to 98% by weight!
