Results 1 to 9 of 9
Thread: 24MP sensor and 24mm Zeiss lens combo question
    Senior Member peterb's Avatar
    Tysons Corner, Virginia
    490
    18
    Just curious as to which combination produces images?
    The a65 (or a77) with the 24mm f2 Zeiss or the NEX 7 with its 24mm f1.8 Zeiss.
    Would love to hear the observations and impressions from anyone fortunate enough to have had the opportunity to compare the output resulting from these identical focal lengths (but differently designed lenses) with their respective 24 MP APS-C bodied cameras.
    Thanks!
    Life is an infinite series of moments called..."now".
    My job is to capture them.
    Senior Member Taylor Sherman's Avatar
    Feb 2012
    Seattle
    390
    Re: 24MP sensor and 24mm Zeiss lens combo question
    I think the difference between the lenses is the largest factor. The 1.8 is a Sonnar, not designed for corner-to-corner sharpness. The Distagon is. Also, you can use the Distagon on the Nex, I do
    I can chime in and say that the 24/2 on the Nex-7 (not exactly what you've asked about, but the only combo that I've used) is a very good combination. Technically excellent, I've used it for landscapes and street/people photography.
    I've seen shots from the 1.8 that have a very different quality to the OOF areas, I'm not sure if the 24/2 will do that if I just do the right thing. But I think optically they are probably quite different, so the answer is no.
    The other thing about the Distagon. . .it retains its sharpness even on full-frame (field curvature / sample variation issues aside). I'm going to be tempted to get an A99 just to use it with.
    May 2011
    Paris, France
    337
    Peter, adding to the excellent comments that Taylor made, the 24mm f:1.8 Sonnar is clearly optimized for short to medium range, where it shines, not for infinity, where it does not. The Distagon, which, unlike the Sonnar, I have not tried, should be able to handle both equally well.
    40
    The Sonnar may be better at near distances than infinity but it is no slouch at infinity either.
    Jul 2009
    The Netherlands
    38
    The 24mm shows both some field curvature and some focus shift. For landscape use this means that the outer edges and corners tend to be out of focus, for example when stopping down to f5.6. One solution, with AF, is focusing at the extreme right or left edge. Doing this makes it a great landscape lens (at least my copy).
    Workshop Member kuau's Avatar
    Apr 2009
    Park City, UT
    1,071
    34
    Taylor,
    Anyway you capost a picture of your NEX7 with the 24/2 mounted on it. I'm curios to see the size of the lens on the NEX 7
    Steven
    Quote Originally Posted by Taylor Sherman View Post
    Steven Kornreich
    www.kuau.com
    Feb 2012
    Seattle
    390
    Sure, kuau - yes it's kind of large, relatively. I do like the lens but still of course wish it were smaller. And it's not light - I think the lens/adapter combo is around 500 or 600 grams.
    DSC03990.jpg by Taylor Sherman, on Flickr
    DSC03992.jpg by Taylor Sherman, on Flickr
    DSC03993.jpg by Taylor Sherman, on Flickr
    Here are a couple of pictures I took with it last weekend:
    DSC01550.jpg by Taylor Sherman, on Flickr
    DSC01477.jpg by Taylor Sherman, on Flickr
    numero
    The E-mount 24mm f1.8 has the characteristics of a portrait lens I guess. The center is plenty sharp but roll off gradually toward the edges - which is why I sold it off two months back.
    Apr 2009
    Park City, UT
    1,071
    34
    Taylor,
    Thanks for posting those images.
    Yeah it looks like a pretty big lens on the NEX7.
    Oh well I think I am going to wait for the A99..
    Steven
    Steven Kornreich
    www.kuau.com
