Results 1 to 10 of 10
Thread: RX1 - Histogram doesn't reflect changes in exposure
    Apr 2008
    Mechelen, Belgium
    22
    I noticed that when shooting my RX1 (in M-Mode) that neither the larger histogram nor the small one (in the right lower corner of the LCD) really reflects exposure adjustments.
    In S and A mode there are some almost "hesitant" reflections of changes visible in the histogram but very minimal.
    When I like to "expose to the right" and therefore increase exposure these increases are not really visible in either histogram.
    Changing between Auto ISO and fixed ISO values doesn't make much of a difference.
    So far when during exposure the histogram indicates that exposure e.g. is too much to the left, I can not use the histogram to follow the effect of gradual exposure increases until clippings may occur.
    What mistake do I make?
    (I placed this tread in another forum but did not get any advise)
    Santa Monica, CA
    2,272
    2
    Re: RX1 - Histogram doesn't reflect changes in exposure
    Nobody knows?
    Shashin's Avatar
    May 2011
    Florida, USA
    4,497
    141
    No problems changing my histogram.
    Feb 2011
    Chicago
    101
    Could it be related to if you have viewfinder exposure simulation on? I'd check on mine but its in repair right now.
    Apr 2008
    Mechelen, Belgium
    22
    Quote Originally Posted by petetsai View Post
    My RX1 is at Sony for solving this histogram problem.
    However I do not understand what you mean by "viewfinder exposure simulation"?
    Harry
    Senior Member 4season's Avatar
    Colorado USA
    518
    If the RX1 is like the NEX-7, there's a menu item for that:
    Setup: Live View Display: Setting Effect On
    Else the camera will do exactly what the OP describes, with histogram and display ignoring all changes to exposure settings.
    Santa Monica, CA
    2,272
    2
    "If the RX1 is like the NEX-7...."
    It is; thanks.
    Apr 2008
    Mechelen, Belgium
    22
    Quote Originally Posted by 4season View Post
    I just got my RX1 back from the Sony dealer and indeed I had Live View Display switched "off". After switching this "On" the histogram now behaves normally with exposure changes.
    Thank you for your advise!
    Can you perhaps explain why I need Live View switched on (apart from the histogram function)?
    If LV is switched off I still get Live view (but no histogram adjustments).
    Why is there an option to switch LV off if this disrupts the normal functioning of the camera?
    Thanks again,
    Harry
    Jul 2009
    363
    3
    There is no real knowing why Sony do their menus as they do, but one thing - they let you do almost everything once you discover the secrets. You could try futzing with the 'monitor' and 'viewfinder' settings also, as there is a checkbox there to give you another option for the LCD, what I do is make a change and check it out carefully for behaviour changes. Gary Frieddmann ha said it's not worth his while to write an RX1 user manual. Someone will..
    BTW, I strongly suggest you try to forget ETTR with this near bulletproof sensor, it's an outdated kludge dating from poor DR, poor SNR sensors back in the early days of digital...people still read old stuff on Luminous Landscape and unwittingly bugger up their colour and tone curves using this crazy idea.
    Like so much in life - high fat diets are bad for you; humans are heating the Earth; high levels of debt don't matter - the 'expert' or 'scientific' view is fallacious and anything but scientific...humans absolutely run on belief systems and ideology trumps fact, observation and experience every single time, almost.
    Distrust expert opinion, unless verified independently! Well, you can believe Zeiss.
    Los Angeles, California, USA
    1,965
    Quote Originally Posted by Muizen View Post
    Thanks again,
    Harry
    It is generally used for shooting strobes.
