Results 1 to 10 of 10
Thread: A7/A7R silly question?
    Senior Member Rawfa's Avatar
    Nov 2008
    Rio de Janeiro
    2,393
    Since Sony them selves said that some e-mount lenses may cover the FF mount on the A7/A7R, would it be possible to use a focal reducer (speedbooster, lens turbo, etc) on them?
    Nov 2008
    Rio de Janeiro
    2,393
    Re: A7/A7R silly question?
    From Sony NEX System : Canon EF Lens to Sony NEX Speed Booster I can see that at least the metabones version won´t cover the full frame:
    "This Speed Booster™ is designed to cover an APS-C image circle which is not big enough to cover a full-size 36mm x 24mm sensor."
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,601
    21
    Quote Originally Posted by Rawfa View Post
    That is correct. No lens you mount with the SB will cover the FF (already checked to be sure). That is the nature of the design.
    Nov 2008
    Rio de Janeiro
    2,393
    That´s too bad. I could already imagine some fast super wide angles
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,601
    21
    What I said applies only to the Speed Booster. That gives ~tele-centric projections (that is the whole point).
    The knock offs may not do that though.
    Senior Member kweide's Avatar
    Germany
    1,631
    A7R and a 85 f1.2 prime... that could be my next portrait choice camera
    __________________________________________________
    Part of the Wonderland
    see more ( NSFW ) on : http://www.klaweide.de
    Jan 2009
    College Place, WA.
    790
    Quote Originally Posted by kweide View Post
    Nikon F mount.
    Apr 2008
    1,446
    Haha
    I was thinking exactly the same thing, the "Speed Reducer" would essentially have an optical lens set that would have to take a APC-C image, and magnify it to fill a full frame sensor. The outcome would be a much lower resolution image on full frame and sacrifice of approx 1 stop of light.
    Any advantage of doing this would be lost, so not only would you end up with a lower IQ full frame high resolution image, but also you would lose 1 stop of light.
    No go I think
    Senior Member hot's Avatar
    May 2009
    Austria
    2,170
    Metabones Canon EF Lens to Sony NEX Smart Adapter (Mark III) is Metabones third-generation Smart Adapters allow you to mount Canon EF and EF-S mount lenses on Sony a7R and a7 full-frame cameras. It retains existing features such as a detachable AS-style quick release plate, chrome-plated brass for all mounting surfaces, EXIF, autofocus and image stabilization (IS) lens support.
    Jul 2010
    495
    I hope they're working on a speedbooster for hasselblad lenses.
