Results 1 to 7 of 7
Thread: APS-C e-mount A7/A7R lenses test
    Senior Member Rawfa's Avatar
    Nov 2008
    Rio de Janeiro
    2,393
    Vivek, what do you think? Does it seem doable to change these APS-C lenses for work well on FF?
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,608
    21
    Re: APS-C e-mount A7/A7R lenses test
    So, you lifted that from these guys. : Mobile
    Rafa,
    It hurts me to say this- the 16/2.8 (without its rear baffle) is a definite to fully illuminate the FF (with drastic light fall off). I am not sure about the coverage though! It is the 5/5 Heliar type lens construction that would enable it.
    20/2.8 Possibly.
    50/1.8 OSS (without rear baffle) most definitely! According Sony the OSS will work on A7/7R!
    I am unsure of the E 24/1.8.
    30/3.5 Yes. Full illumination (without the rear baffle)!
    18-55 from ~24mm. OSS will not work.
    Those are lenses I have. I will check on 20th Nov.
    I want to get hold of a 10-18 f/4 OSS. This is the most intriguing lens in the E line-up, AFAIC (after the advent of A7/7R).
    Mar 2008
    Santa Monica CA
    83
    does anyone have photos of the sony 50 1.8 ($250) on the A7? How much crop and resolution do you lose? would it be a quality and cheap portrait lens 75mm equivalent on the a7?
    Apr 2014
    Marin County, CA
    593
    That was my wide angle lens for the A7 until the FE16-35 was released. Full coverage at around 12-15 mm, and there is a LR lens profile floating around.
    Like many APS-C lenses on a FF camera, it was super sharp in the center, and got a bit fuzzy in the corners. Light fall off on the edges was easily contained.
    Here is a shot I took with the lens in the Hoh Rainforest in Washington:
    Full res here:
    https://www.dropbox.com/s/i358m1ri36...%20FR.jpg?dl=0
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,608
    21
    Thanks, Dave. Somewhere between then and now I actually bought that zoom, tried a ~ 10 shots or so and returned it. There was something disconcerting about the images that I can't pin point. Illumination of the full frame, as you mention, in that FL range is there.
    Quote Originally Posted by antara View Post
    No photos to share. I would say not worth the bother.
    FWIW, the 24/1.8 (without the rear baffle) covers more of the frame than the 50/1.8 and the quality is much better as well.
    Dec 2014
    NYC
    77
    Here is 50mm 1.8 OSS on A7R, wide open 24MP equiv crop ~ 61mm f/2.3 equiv (1.22x crop)
    So on A7 you can get around 16MP at max opening without removing the baffles. Normal 1.5x crop gives you 10MP.
    Senior Member ggibson's Avatar
    Oct 2009
    SF Bay Area
    743
    Might as well get the 55mm f1.8 and crop it how you like.
    If you're looking for an affordable option, the Sigma 60mm f2.8 could be good at $220 new. I tried it out for a while before I picked up the 55. The 60mm covers a decent amount of full frame with the baffle removed, especially at macro distances. You could crop 1.2x and get rid of pretty much all of the corner vignetting (so around 20MP on the A7). Here's a link to a few shots that I have online and a non-cropped sample for you:
    https://www.flickr.com/photos/graham...7646958328744/
    http://www.flickr.com/photos/grahamgibson/
