The FE 35mm F2.8 ZA...
tashley
OK, I just got back from an hour of shooting in reasonable daylight at all sorts of apertures, inside and outside, near and far, and I am liking the lens a lot more now. In general, though sometimes it doesn't quite work, edges are sharp enough by F4. I still have to bottom out some subtleties but in general the lens is giving good results, nice and sharp and contrasty, nice but not amazing micro-contrast, pleasant bokeh, quite close focus, pretty good at most subject distances, a good all-purpose lens.
In fact, for most situations, I'd rather shoot this lens on the A7R than the Sigma Art 35 on a D800E, regardless of the size and weight differences. It's not stellar, you can't rely on it to alway have sharp edges like you can with the lens on the RX1, but given the task it is set in dealing with the sensor, it seems like a reasonable set of compromises and is fun to use. Maybe they could have made it a little cheaper, or a little better at the as-is price, but a cursory first walk indication is that it does the job…
I am currently uploading a LOT of full size files to this gallery and though non is an artistic tour de force, there are shots that show a range of the lenses uses and results that might be useful to some.
cunim
Regarding corners, here is a pic of my hangar door. Left 35 FE at f3.5. Right and just for gross comparison Summicron-R 50mm at - well, I forget. Something in the sub f4 range. LR raw import with nothing at all done.
On my calibrated monitor there is a definite magenta tinge to the snow in the corners of the FE image. I would not say the 50mm corners are much sharper but the color is even.
I love the form factor, lightness, ease of use of the 35 FE. Very sharp except at corners, and flare is well controlled so contrast is great. Sadly, the problems will probably outweigh the benefits and I will return it. No idea what an alternative would be.
k-hawinkler
Doesn't the camera with native lens also perform some diffraction correction?
What effect does that have? Can that be switched off?
Thanks.
tashley
K-H,
There's no option to turn it on or off and it isn't clear to me whether it is working with RAW files or not. The menu options are for colour, chromatic aberration and distortion, all with either Off or Auto.
tashley
Cunim, I see that too but I have to say that it wouldn't stop me from using the lens because I would just keep a library of calibration shots for use if as and when required using the Lightroom Flat Field plugin. I wasn't getting good results from Cornerfix and I found it a hassle, but doing it all in LR and with such good results has changed my mind.
If you have time, look through the images I uploaded today and let me know if you see it as a problem in more real-world use?
I am, more than anything, snow landscape guy, it is my favourite genre: but armed with the correct library of correction profiles I think I'll end up happily using this lens for that sort of work. Last winter I did a lot with the RX1 and rarely encountered a problem, and could fix it when I did...
D
Deleted member 7792
Tim,
After seeing these latest images, downloading the JPEGs and viewing them at 100% in LR, I'm convinced that the A7R-FE 35mm f2.8 combo will be well matched to my shooting interests. The DSC6419-22 series in particular convinced me on sharpness, and DSC6442 and DSC6455 had a medium format "feel" to them. I won't give up the RX1, but it may be a lonely elf on the shelf. Thanks again.
Joe
cunim
Tim, I see no problem in your real world examples. By the way, thank you for providing them and for an interesting blog. My issue is that, with winter coming, I will simply stay in the studio and hibernate - so need for a wide lens is minimal. I can give this back now, get the 55 in a few weeks, and decide on wides once the great and good have pronounced.
Very interesting circular color patterns in your flat fields. They look like a broad moire between the beam angles and the microlens angles. Don't believe I have seen that before.
The corner-corner shading is about 20% of dynamic range, actually a bit more than that. Can't tell if your images show the marked corner softness mine demonstrate. Perhaps my copy of the lens is worse. No matter. I can always pick the 35 up again later and I will be interested to see how you feel once the smell of new plastic is gone.
Peter
tashley
Very interesting: I have a sense that 'under the hood' there is something unusual going on with this lens. Like avery good artificial sweetener, the dish is tasty but you almost subliminally know there's something not 100% right in it….
frozenbb
Indeed, thanks Tim for all of your sample shots and observations. They're really useful for those of us trying to get a handle on this odd little lens!
Any chance you could be persuaded to post/provide your "library" of flat field correction photos for the FE + A7R combo? Or at the very least, to walk us through your workflow and gear used to create such high-quality correction photos?
tashley
Sharing would be difficult (you need the full size DNG file and uploading several of them will take forever!) and also not optimal for you - each camera and lens combination is best served by bespoke profiles made thereon. But nonetheless next time I am near egregious bandwidth, I will upload some key apertures.
To make the calibration frames you need something like this.
Basically you set the lens to infinity manual focus and then at each major aperture, shoot a frame with the sheet pressed hard against the front of the lens and positive exposure comp of about 1.5 stops, but make sure none of the channels blow. [Note: to get perfect corrections, you need to make them at exactly the same focus distance as well as the same aperture but in practice it won't make that much difference, though very close range shots won't work as well if corrected with calibration files shot at infinity]
You then have several options:
1)Shoot a set for (each major aperture) and either import them into LR as DNG, or import as RAW and convert to DNG. Export all these DNGs to a folder somewhere on your drive, and name them so as to be easily identified (e.g.. 35mmF2.8_atF8.dng). Then in Lightroom, select the image you want to correct, convert it to DNG if it isn't already and re-import it then select it again and go:
File>Plugin extras>DNG Flat field>Apply External Correction
you will then be required to locate and select the relevant calibration file from the folder you made already. Then select Color Only or Color and Falloff and… a new, corrected DNG file will be made with FF added to the filename.
or
2) Shoot a calibration file for every shot you take, as you take it: Shoot Granny on the beach, shoot calibration frame with same aperture, shoot baby in sea, shoot calibration frame. Import to LR with Convert to DNG option at Import and then select the frame you want to correct then and then option select the calibration frame then
File>Plugin extras>DNG Flat field>Apply Interleaved Correction
In practice it could me more complex than this: you can shoot your original frames with in-camera corrections on or off. Different and matching calibration shots would be needed for each. In-camera correction will usually be enough so I will be shooting that way and then adding a further correction from my library when needed BUT this adds one step to the imaging chain and is not the best, just the most practical, way of dealing with the issue. For important shot, turn in-camera shading corrections OFF and shoot the frame, then shoot your calibration frame and apply it in LR.
Phew.
frozenbb
Tim, that's excellent. Many thanks for the extremely detailed reply! It will definitely add some time to my normal workflow, but I can't argue with the results. I do wonder why Sony failed to add complete correction for the lens from the beginning, and chose instead to offer such partial solutions. Here's hoping they'll see the wisdom in including more complete FE 35 corrections into a future firmware update.
Also, I had been wondering if it was necessary to shoot a calibration frame for each shot, as opposed to having a set of generic correction profiles on hand. Unfortunately, it seems that for good results for critical work the former is required.
Anyone know of any decent alternatives to the Universal Lens Calibrator that Tim linked to? £49.00 seems rather steep for a small piece of plastic. =) I wonder if a medium white version of this would serve the same function:
Cast Acrylic Sheet - .125" Thick, Medium White, 12" x 12" - Pick: Color, Thickness, Size: Amazon.com: Industrial & Scientific
I suppose it's possible that product has ugly casts of its own.
cunim
My own theory, the ff correction is bothering you. I know that even with an LCC made for each MF image in C1, the less correction there is the better I like the output image - just speaking technically of course.
The real issue with vignetting on the 35 is the steepness of the falloff. If the 20% of dynamic range falloff center to edge is a fairly smooth transition, it is what we expect from a lens and no big deal. This falloff curve, however, gets rather steep as you hit the corners. The steeper the curve, the more bothersome the effect. I stopped using the SpeedBooster with my NEX because it did that (and the MTF thing I mention below).
As to other effects of flat fielding, sorry if I review basics but it helps me think. In the context of an image that contains a goodly portion of dynamic range at the corners, a proportional lift is fine. However, if the image only contains a small part of the range at the corners (e.g. sky or snow) bumping those pixels by 1.2 can increase noise and artifacts by a very large amount relative to the local information. That is why falloff-corrected skies tend to have what I call "tense" corners. This bothers my eyes. When using LCCs with skies I tend to just correct color casts and do only minimal vignette correction. The color casts are usually a small proportion of the color space so that works fine. Perhaps that is all you do as well?
Getting back to why the 35 may seem strange - and I stress that this is just for me - it is not only the sudden vignetting. It is also the similarly sudden transition of MTF as you hit the corners. The transition from reasonable MTF to crud is almost cliff-like at wider apertures. Once I was sensitized to this, I found my eyes checking for sudden MTF transitions in every image I see. Don't know why it bothers me so much but, aaargh, it's like one of those jingles that just won't go away. This effect seems to be the Achilles heel of the FF e-mount and we will just have to see how Sony/Zeiss do with subsequent lenses.
jonoslack
Great stuff Tim - thank you once again - . . . . . . I'm assuming there's no sign of smearing at the corners?
The vignetting looks entirely manageable - the colour shading less so - but not dreadful.
all the best
tashley
I'm not so bothered by the colour falloff, my colour vision isn't the very most accurate out there and I have reasonable tolerance for some colour shading depending on subject. I, like you, prefer to leave some vignetting and though the examples I have posted here are 'the full Monty' corrections to show how they work, I will mostly be using colour falloff only corrections. So I think what I am detecting is the MTF which, as you say, has some dramatic falloff. It also has quite a bit of wave and a heavy whack of astigmatism. I think you are right that all this contributes to the effect.
But I also notice that the edges of the frame stretch and contract at different apertures. I need to bottom this out more. I also think there's some focus shift at longer distances that works with the field curvature and astigmatism to make the lens behave a little oddly as you stop down. I think we need a big team think on this one!
tashley
all the best
A bit of smearing but not much, and it seems to come and go with distance, subject shape and aperture, quite hard to pin down. Grrr! I posted lots of examples in the gallery and some I didn't post, of the harbour side scene but shot with the camera on the diagonal, I will post because they are interesting for corner fiends!
