Results 1 to 4 of 4
Thread: Sony Vario-Tessar T* FE 24-70mm f/4 ZA OSS Lens
    Apr 2008
    210
    14
    This is the next lens after the 55mm and the first zoom. I really have great hopes for this, as it would make a convenient travel lens. However, there are significant concerns when I compare the ZA zoom with the relatively new Canon EF 24-70mm f/4L IS, particularly filter size. The Sony-Zeiss is cheaper than the Canon by $300.
    Canon:
    Minimum Focus Distance 1.25' (.38 m)
    Magnification 0.21 - 0.7x
    Maximum Reproduction Ratio 1:1.5
    Groups/Elements 12/15
    Diaphragm Blades 9
    Filter Thread Front: 77 mm
    Dimensions (DxL) Approx. 3.28 x 3.66" (83.4 x 93 mm)
    Weight 1.32 lb (600 g)
    Sony Zeiss:
    Minimum Focus Distance 1.31' (40 cm)
    Magnification 0.2x
    Groups/Elements 10/12
    Filter Thread Front: 67 mm
    Dimensions (DxL) Approx. 2.87 x 3.72" (73 x 94.5 mm)
    Weight 15.17 oz (430 g)
    I suspect that vignetting and corner performance will need to be "enhanced" significantly by the Sony A7 or A7r in camera. The lower weight is great, but there is a big difference in filter sizes. The Sony lens barrel is slightly longer and narrower.
    Apr 2008
    210
    14
    Re: Sony Vario-Tessar T* FE 24-70mm f/4 ZA OSS Lens
    MTF comparison Zeiss FE f/4 and ZA f/2.8.
    Knorp's Avatar
    3,998
    Sorry, but why is the filter size a concern ?
    And what other significant concerns are there ?
    Thank you for the information, always good to keep a close eye on the competition ...
    Kind regards.
    Bart ...
    Apr 2009
    384
    I did not know until I went to look for some..all sold out because of this lens
