Results 1 to 3 of 3
Thread: A7 manual lenses stop down metering ??
    Jan 2012
    133
    Hi.
    Is this correct:
    1) When you use a manual focus F mount lens, Nikon or Zeiss or ... with the Novoflex adapter, you must meter stopped down to the shooting aperture?
    You can turn the ring on the adapter to open up the lens for focusing but have to stop back down for metering and shooting - kind of like the old time pre-set lenses of the 1960"s?
    2) Using a M mount lens, its meter and shoot at the working aperture only, unless you want to work the f-stop ring back and forth a lot?
    thanks,
    Robert
    Senior Member Ron Pfister's Avatar
    Oct 2012
    Switzerland
    661
    Re: A7 manual lenses stop down metering ??
    1) Correct - but there's a lot to be said for focusing at working aperture, because you avoid any focus-shift issues by doing so.
    2) Same as above - this basically applies to all lenses whose aperture can't be controlled by the camera body.
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,603
    21
    Quote Originally Posted by OlderThenDirt View Post
    Hi.
    Is this correct:
    thanks,
    Robert
    Yes and yes. Same old stuff. Nothing new.
    for 3 use the wheel/dial to correct the exposure compensation (one has to "menu dive" in the M digitals for this!) instead of changing aperture.
