Results 1 to 22 of 22
Thread: Sony A7 1 & 2 Memory Dial Mode
    Jun 2011
    52
    Is there a way to modify the Sony Memory 1/2 parameters or do they always have to be set up from scratch?
    Cheers
    Jan
    Senior Member dchew's Avatar
    Feb 2011
    Northeast Ohio
    970
    Re: Sony A7 1 & 2 Memory Dial Mode
    If you want to make a change to one or two settings, switch to that dial position, say "1", and adjust whatever parameter(s) you want.
    Then go to Menu, Camera Settings, Memory, Select register (1 or 2), press the center button of the control wheel.
    That saves those newly-changed parameters.
    Dave
    davechewphotography.com
    23,623
    2555
    I still need to set this up. I had this type of setup with my D800e with timer,mirror up and delay for landscape work. Glad Sony did the same, I just need to do it. Thanks Dave that gave me a clue how to make the changes
    www.guymancusophotography.com
    Feb 2011
    Northeast Ohio
    970
    Guy,
    The first time you set them up you should start from scratch, which basically means the first step is different; don't turn the dial to position 1 or 2. Instead set up the camera the way you want in whatever mode you want the setting to act like. For instance, if you want aperture priority, set the dial to A, and set up the camera just the way you like, including what you want the starting aperture to be, i.e. f/5.6 or whatever.
    Then go through the menu as indicated in my other post.
    If you are like me, you will forget some specific setting or want to change it a bit after the initial setup. That's when you would turn the mode dial to 1 or 2 initially, simply because all the other settings are where you want them already.
    Hope that made sense...
    I have "1" set for manual, auto iso. Essentially a hand-held position. "2" is for tripod mounted: time delay, iso 50, aperture priority.
    Dave
    Jun 2011
    52
    Hi Dave,
    thanks for help!
    Cheers
    Jan
    23,623
    2555
    Thanks Dave I would setup similar like you. I would reserve number 2 as landscape settings as well.
    OT but I just noticed RRS has the L bracket in stock. I just ordered it. Now I have way too many plates. LOL
    I think I will put that Sugru stuff on the plate to create a cushion. I am in the believe that a rubber plate helps with dampening the shutter. Also a bigger mass of plate why I ordered it. Call me stubborn. But I have yet to put on a plate on this thing that has made me happy yet. There too wide and interferes with the LCD articulating arm.
    Sep 2011
    1,069
    83
    Guy, the new L-bracket is quite interesting in that the vertical piece can be removed easily so you can go back to a compact baseplate as needed. I love L-plates, but hate adding bulk and weight, and this looks like a great solution.
    Sep 2011
    1,069
    83
    BTW, they also have plate for the Sony A-E adapter so you can have a single tripod mount for all A-lenses.
    23,623
    2555
    Yea this one looked really nice from the photo and you can set it up two ways. Ill let you know how it is but this might be the ticket for the A7r . I did pick up the Sony remote cord but the dang thing is like 65 dollars and if your a video shooter it has a zoom feature. i may return it as its not really that small. I bought a 19 dollar one off brand at Calumet but has the wrong connection and so does the dang Metz flash I got so going back today to get this straightened out. The picture on the box had the standard foot but the flash was the old style connection. I might just get the Sony instead and be done with it. The Metz looks nice though. Ill see what they have
    Sep 2011
    1,069
    83
    Guy, I got one of these, 80bucks and has manual control and swivels. Works well as an optical trigger for me...
    SAMSUNG NX SEF-20A FLASH ED-SEF20A/EP
    23,623
    2555
    That looks nice to have in the bag at all times. I could use that as well. the big one is for the PR grip and grin corporate work I have to do. You know the bread and butter clients. LOL
    But that little one looks perfect for fill and small in the bag
    Sep 2011
    1,069
    83
    The size is what I needed, along with the manual control and swivel power. I always prefer off camera flash anyway. When I use it, I just setup a couple of external optical slaves and works great.
    Oct 2009
    123
    It's too expensive, but it's the only game in town (and by the way, what isn't "too expensive" when talking camera gear). I like the USB (actually, micro USB size, but with different pins) rather than the old 3 pin. The 3 pin plug often required rocking the plug to remove from the camera. I like the ability to actuate the video, something the old wired remote couldn't. I like the new remote's removable clip. It's nice to clip to my camera's installed wrist strap (or one's neck strap) for tripod work, rather than having the remote dangling.
    I wish Sony had made the new plug right angle as was the old remote plug. The new USB straight plug fouls the tripod clamp when working in portrait mode. As I'm using mostly adopted Sony A mount lenses (for now), and I mount the L plate on the adapter, that isn't a problem. Using a generic L plate, with slots for the tripod screw, I can extend the side plate leg to clear the inserted remote plug. That wouldn't be possible with the dedicated RRS L plate. The a7r may be the first camera in the last 4 I don't purchase a dedicated RRS L plate for.
    Two tips I'll pass on. First, when the camera goes to sleep, a half press on the remote's shutter button doesn't wake the camera. I spent some time in the camera menu before finding the "power" switch on the side of the remote. Slide the switch up to wake the camera (and Sony,make the next firmware release wake the camera with a half press of the remote shutter button as GOD intended).
    I found it almost impossible to determine the correct side of the remote plug to fit into the camera without close examination. That's difficult to perform in the dim light of pre-dawn landscape shoots. I used my soldering iron to dimple the remote's plug, the side facing to the rear. I can now feel the correct way to insert the plug.
    Graham
    winnipeg & neelin
    72
    RE: remote options
    Quote Originally Posted by GrahamB View Post
    I've got a Nex7 and an A7r and my cheap chinese vendor infrared remote that works on the Nex7 also works on the IR port on the handgrip. Don't know if advanced functions can work via IR if there are more sophisticated remotes but the simple shutter/2sec selftimer buttons work on this two button remote. ~$5. delivered from China.
    Can't say I've noticed publication that there is even a IR remote port on the A7r.
    Robert
    23,623
    2555
    Graham
    Thanks Graham good trick. I'll keep my sony and returned the generic
    Jan 2012
    384
    I was able to trip the "Bulb" setting of my A7R with my supplied Remote Commander wireless remote, the one I received with my old a700 years ago.
    One push to open, another to close it, timed it with my watch.
    Ideally, I'd be wanting a programmable intervalometer style like I bought cheap on the bay for the a700.
    Oct 2009
    123
    Quote Originally Posted by neelin View Post
    RE: remote options
    Robert
    There's an IR port on the front of the camera, and I have both the Sony RMT-DSLR1 (that came with the a700), and the RMT-DSLR2 released with (or about the same time) as the a99. They're basically identical, but the DSLR2 will start and stop camera body video.
    One may also use the free Sony remote control app, and their smart phone or tablet. https://www.playmemoriescameraapps.c...9014_00-F00002
    Sony has an intervalometer app for several of their NEX cameras. I'm sure a7 support will be added shortly.https://www.playmemoriescameraapps.c...9014_00-000003
    For me, nothing beats a wired remote for tripod work.
    Graham
    Sep 2011
    1,069
    83
    Just tested the new version for iPhone with the new version for the A7R. Pretty awesome. I posted a new thread on it.
    Guy, I think with your iPad or iPhone, you'll have all the remote capabilities you'd need. Just remembered....not sure of bulb, need to go check.
    Cheers..
  19. #19
    23,623
    2555
    I just saw that and going to look into it. I initially was thinking out in the field wifi just don't exist. But with ad-hoc it's worth a try. I'll still keep my cord but very interesting
  20. #20
    23,623
    2555
    Just went into a Sony store here in LA and was looking around. I wanted to try the 55fe but nothing there
  21. #21
    Dec 2013
    22
    Quote Originally Posted by dchew View Post
    Guy,
    Dave
    I don't see it quite as fluid as you say. I find that I cannot save while in [1] or [2] dial modes. I have to move to another mode (MSAP) then go, as you say, to menu>camera>memory then save.
    If I want to make a minor change in [1] or [2] it's not so simple. When I go to [1] or [2] then back to say, manual, the settings are not carried back to M. This is kind of a problem because in order to make a minor change I have to reenter ALL the settings then save again.
    Also I wanted to setup manual flash with ambient underexposure. With underexposure it makes sense to set Live View Display setting effect OFF. That setting is not possible to save to either [1] or [2].
  22. #22
    Feb 2011
    Northeast Ohio
    970
    Quote Originally Posted by ferrellmc View Post
    Hmm. To your point, I'm not sure how you could change to a different mode (MSAP). I also tried Live View Display setting and that is indeed global. It seems there are some settings you can change the way I describe and some you cannot. Sorry for the confusion.
    When you first switch into [1] or [2], it looks like you can run through four screens that show the settings that are specific to that memory position.
    Dave
