Page 2 of 2 FirstFirst 1 2
Results 51 to 98 of 98
Thread: JLM L-plate for A7/R
  1. #51
    Brooklyn
    4,043
    1253
    Re: JLM L-plate for A7/R
    working on it this weekend
  2. #52
    Brooklyn
    4,043
    1253
    looking over the L-plate with battery grip, i have a question:
    typically i make my L-plates so the camera lens can be centered over the L-plate in portrait mode, however, the extra thickness of the battery grip means the L-plate would need to be another 2" longer, a total or 4-1/2" tall, all supported from the bottom plate. if i used a typical 2-1/2" L-plate, the camera would be better supported, the overall bracket would be tidier in size, but the lens center would be 2" off the center of the plate.
    what do you think?
  3. #53
    New Member KiboOst's Avatar
    Mar 2014
    France
    16
    Just reading this message, and I'm desperately in need of A7R+Grip L Plate.
    Actually, I use A7R with metabones adapter and Canon lenses, and can't mount the vertical grip without losing ability to clamp adapter foot. (see this blog post)
    What I dream of is an 'always mounted' L bracket on vertical grip, not ruining handling, and without any part to slide or move or unscrew/screw to open battery door or slide connections doors. I don't want to use a screw key each time I need to get battery out etc. The side part of the L could even be on another plane (toward the lens) to free grip battery door (my RRS 1DsII L-bracket is like this and never bother me). Not being perfectly centered between portrait and landscape isn't a problem too.
    But having to screw and slide would be a definitive no-no.
    Now, can't wait to see your design. I was about to design one in 3D and get it machined, but not much time right now.
  4. #54
    Jun 2011
    52
    Received this mail today:
    Update for Really Right Stuff Support Case #3417 - "L-Plate for A7r with Battery grip."
    We are in the process of researching and designing a custom plate for use with the added battery grip on the Sony A7/A7R. If we decide to make a custom plate for use with the added grip, you will see such an announcement made on our website homepage as well as on our company Facebook page, and in our monthly newsletter.
    Please let me know if you have further questions.
    Erik
    Really Right Stuff, LLC
  5. #55
    Brooklyn
    4,043
    1253
    my design is complete and will get machined this week. i decided to keep the L-plate end at 2-1/2" above base of grip. should a taller plate be required, it could be retrofitted.
    Sony has chosen to make a huge battery door in the grip, and there is no practical way to allow battery access with the grip plate installed that I can come up with without compromising strength or add a huge offset (ruining handling). it is not such a big deal to use an allen key, loosen the plate from the grip, rotate it out of the way and change the batteries. since there are two batteries, the frequency of change will be longer anyway.
    jm
  6. #56
    Mar 2014
    France
    16
    Why not use such rss design :
    http://thelearninglensman.com/wp-con...111910-011.jpg
    Just perfect handing and usability.
  7. #57
    Brooklyn
    4,043
    1253
    hmm...earlier response disappeared
    unlike the Canon, the sony uses a hinged battery door and the swing is problematic
    i will look into a tool-less fastener
  8. #58
    Mar 2014
    France
    16
    What I think frustrating on your 'without grip' version is that you can't let it slided. I'm 90% of time on tripod with connected cables, so I would let it always slided. But due to the part under the door, I couldn't do that. I would have cut this part to use it ;-)
  9. #59
    Brooklyn
    4,043
    1253
    my L-plate versions CAN slide; the bolt opening is a slot allowing enough movement so you can open the doors, attach your cables and still fit on the tripod in portrait mode. difference between mine and RRS is mine is one piece.
    that concept does not work with the grip version because of size of the battery door, but the cables are still accessible
  10. #60
    Mar 2014
    France
    16
    Of course yours can slide, what I want to say is you can't let it always slided for cable doors access, as it block battery door.
    I'm not saying this one is better, this one is badly designed etc, don't get me wrong. Just putting some ideas about designing the best one. And yes you are entirely right, the sony vertical grip door design is very bad regarding L bracket fitting.
    Also, are you confident enough in vertical grip screw fixation to handle let's say body+grip+metabones+24-70 2.8L II ? Of course with a 70-200, it will be mounted on tripod collar, but dunno if grip screw and sony lens mount are as robust as Nikon/Canon DSLRs ?
    And on a curious part, how do you design it ? Do you use some 3D tools with a 3D model of A7R+grip ?
  11. #61
    Brooklyn
    4,043
    1253
    i measure the camera shapes using calipers and micrometers and a coordinate measuring machine; drawings are done in 2-d Autocad (usually going through several iterations), then CNC machining programs generated. The profiles and interior cutouts are done from plate on the CNC waterjet, then the exterior machining and detailing done on a vertical CNC mill (three or more different tools used)
    all of my bases rely on some sort of mechanical stop (in addition to the screw) so the base will not rotate. for the sony with vertical grip, i am using the series of grooves in the rubber base, making matching ridges in my baseplate. probably the weakest point will be whatever secures the metal tripod threads into the plastic of the grip itself.
    i agree, the slid-over L-plate grip does block the battery access and i accepted that as a trade off for overall simplicity. I did consider leaving the end open so as to not block the battery, and could alwasy make this change should interest warrant it.
  12. #62
    Mar 2014
    France
    16
    Thanks for your time for these explainations. I always love to know and understand how things are done. Can't wait to see your design. Very good idea to match ridges also. Hope the precision tolerance on this part body to body won't be problem. But I'm sure you have the answer lol.
  13. #63
    Dec 2012
    Portland, Maine
    94
    How is that vertical grip bracket coming along? Any eta?
  14. #64
    Brooklyn
    4,043
    1253
    machining it today! pictures by monday-tuesday
    jm
  15. #65
    Dec 2012
    Portland, Maine
    94
    Sounds great.
  16. #66
    23,623
    2555
    Looking forward to seeing it
    www.guymancusophotography.com
  17. #67
    Dec 2012
    Portland, Maine
    94
    Drum roll...
  18. #68
    Brooklyn
    4,043
    1253
    machining is done on first one, will anodize and post a pic tomorrow.
    expect to have the first production run ready by friday this week
  19. #69
    Brooklyn
    4,043
    1253
    L-Plate for grip is done.
    note cute little captive screw with captive, sliding T-bar, no wrench needed
  20. #70
    Brooklyn
    4,043
    1253
    mounted; port doors can open, but plate needs to be loosened and rotated to get to battery. L part is intentionally low to not cover ports and to limit overhang
  21. #71
    Brooklyn
    4,043
    1253
    details:
    CNC machined from 6061 aluminum, finely finished and black anodized. small ribs fit in grooves in rubber base of grip act as rotation stops. fits Arca style and RRS quick clamps. easy on the hands
    supplied as shown but also with allen key and button head screw supplied
    e-mail me, first production run is ready to ship friday, priced at $140
    [email protected]
  22. #72
    Dec 2012
    Portland, Maine
    94
    How might one center the lens over the tripod in the vertical position? I was hoping to be the first customer on this. Looks useless to me.
  23. #73
    23,623
    2555
    Best solution yet. Going to have to get one. That l bracket for the Sony 4 adapter from RRS is not working very well as you can't get your fingers to release button to take just the lens off. Here it's totally out of the way.
  24. #74
    23,623
    2555
    Quote Originally Posted by Thomas Fallon View Post
    For vertical panos you could use a focusing rail and center it
  25. #75
    Brooklyn
    4,043
    1253
    it would require a 4" long L-plate to center the lens in portrait mode and the cantilever would be extreme, compromising the support
    what this solution offers is the ability to quickly change mounts from portrait to landscape and they are quick clamp compatible; hardly useless.
    i could obviously make a 4" long L-plate if you really need that.
    these things are contraptions to some extent, and my way of thinking tries to minimize and simplify and still maintain the functionality
  26. #76
    23,623
    2555
    For me this would work nice on a monopod with long glass like the Minolta 200, Sony 135 which neither have a lens foot
  27. #77
    Brooklyn
    4,043
    1253
    for the hell of it, am making a 4" long L-plate so the lens can be centered, which of course begs the question of whether the base should also slide over, like the A7 L-plate
  28. #78
    23,623
    2555
    Might be nice to have the option John. Myself I would just use my focusing rail with clamp on it than just center camera over the pivot for a vertical pano. I still like your short rail so maybe give buyer the option for long or short. I'll take the short one myself. I'll order next week
  29. #79
    Mar 2014
    France
    16
    I'm really not fan of having to unscrew / rescrew each time to get batteries out. It may finish by ruin the tripod socket screw on the grip :/
    For me such accessorie is 'fix anf forget".
  30. #80
    Senior Member dchew's Avatar
    Feb 2011
    Northeast Ohio
    971
    John,
    For the 4" long version, could ther be a small support piece at the top that goes over to meet the camera near the strap lug? That would help the cantilever. Could have a locating pin/bump and a removable screw.
    Dave
    davechewphotography.com
  31. #81
    Brooklyn
    4,043
    1253
    Guy: will i have to rename the short-long version as a shlong?
    dave: to use the camera in portrait with cables, you need to slide the base over for clearance.
    i am refining things a bit
    Kibo: the damn hinged battery door in the grip is such a pig! loosening the grip and rotating a bit seems the best compromise, and you do have two batteries in there
  32. #82
    Brooklyn
    4,043
    1253
    long version for Sony grip completed, ready to ship:
    ports accessible, room for cabling by sliding the base over, captive folding wing screw.
    L-plate is centered on lens and has an index mark, as does the base. to compensate for the extra length, the L-plate is thicker
    you will have to loosen screw and rotate the base a bit to get at the batteries, no tool needed
  33. #83
    Brooklyn
    4,043
    1253
    rear view showing base slid over for cable access; it will mount to a quick clamp without pinching cables
    and slid back close to camera:
    3/4 bottom view:
  34. #84
    Dec 2012
    Portland, Maine
    94
    Looks good to me. How much and when is it available?
  35. #85
    Brooklyn
    4,043
    1253
  36. #86
    Dec 2012
    Portland, Maine
    94
    Just ordered mine.
  37. #87
    Dec 2011
    15
    John,
    This looks great. How much for the parts to create both configurations of the L-plate (short vertical segment for use when the grip is NOT attached and the long vertical segment for use with the grip installed)?
  38. #88
    Brooklyn
    4,043
    1253
    the L-plate for the non-grip came is quite different from the grip version, no parts would interchange. you would need one of each
  39. #89
    Mar 2014
    France
    16
    On this last version of long grip L plate, can you open the grip batterie door when fully slided, without unscrew it ?
  40. #90
    Brooklyn
    4,043
    1253
    unfortunately not; the battery door is so large and the hinging such that the base cannot move over far enough to clear. you have to loosen the wingscrew a bit and rotate the base out of the way; it does not have to be completely removed.
  41. #91
    242
    I just received John's "L" Bracket for my A7. It appears to be very well made and is extremely light which is a good mate for a light camera like the A7.
  42. #92
    Dec 2012
    Portland, Maine
    94
    Got mine today. Can't wait to try it out.
  43. #93
    May 2010
    San Francisco Bay Area, California
    385
    2
    I ordered L-Plate for Sony a7 / a7R with Vertical Grip. Can't wait to receive it Jim.
    Subrata
  44. #94
    Dec 2012
    Portland, Maine
    94
    Tried mine out, the long version. Everything seems great. A well thought design.
  45. #95
    Brooklyn
    4,043
    1253
    new version of A7/A7R L-plate:
    -shortened so battery access not blocked when slid over for portrait and cable access
    -no-tool wing screw used
  46. #96
    Dec 2012
    Portland, Maine
    94
    Just received my second one. Fast service. I am enjoying using it.
  47. #97
    314
    I love how Arca-compatible plates have evolved over the years.
    For those of us who shoot tethered,
    I wish all plates would have grooves for cables as Foba BALTE/BALPE does:
    except my preference would be for the grooves to run parallel with the length of the camera body and dovetail.
  48. #98
    Apr 2014
    130
    I am hoping someone here can please help me. I am looking to order a L-Plate for my Sony A7R and ideally would like to be able to use it in conjunction with the Metabones V3 L-Plate from Hejnar photo. I see that Fred Miranda has had success with the Markins L-Bracket but that one does not allow access for using a cable release when used in the vertical format on a tripod.
    I have also read that the RRS L-Bracket can not be used alongside the Hejnar Metabones L - Bracket.
    Any idea if the JLM L-Bracket (the newer one that allows access to the battery compartment) is able to be used in conjunction with the Hejnar Metabones L-Bracket?
    Ok, thanks so much, any suggestions or advice would be greatly appreciated!
