Results 1 to 9 of 9
Thread: Finder/ Monitor behavior on A7r annoying!
    Feb 2010
    Nashville, TN
    172
    I have just started testing my A7r in the field and I am finding a most annoying behavior that I hope there is a workaround for. When I zoom in on an image to check for sharpness and try to examine with a loupe, the LCD goes black. I know this is set at auto in my settings but my only option seems to be auto or leave one or the other on. Is there a workaround to be able to leave the LCD on? How else would I be able to check for critical focus?
    Thanks,
    J. Paul
    Member wuffstuff's Avatar
    Mar 2009
    240
    2
    Re: Finder/ Monitor behavior on A7r annoying!
    Magnifying the image on the LCD might be a way to check for criticality after the image is taken.
    Manchester/Jerusalem
    2,652
    290
    Why on earth would you use a loupe on a tiny jpg rather than zooming in on screen?
    Feb 2011
    Eads, Tennessee
    1,033
    I have found the evf when magnified to be the best method for checking focus The LCD goes black because the camera is auto sensing and resorts to evf mode when your face gets close to the camera.
    Victor
    Feb 2010
    Nashville, TN
    172
    Thanks for your replies! I guess I will use the magnified EVF and see how that works for me.
    J. Paul
    k-hawinkler's Avatar
    Dec 2009
    The "Land of Enchantment"
    3,298
    Quote Originally Posted by jpaulmoore View Post
    J. Paul
    Thanks. That's what I do.
    And the diopter adjustment works great so I can shoot without glasses.
    I also like the two magnifications up to 14.4x.
    With best regards, K-H.
    Mar 2009
    Massachusetts and Vermont
    947
    I have essentially the same problem when I want to use a loupe on the LCD to examine the magnified Live View. The screen goes black. That should be possible, but I have not figured out how to do it.
    hcubell
    www.howardcubell.com
    Senior Member mjm6's Avatar
    Jul 2009
    Sacramento, CA
    526
    15
    You can program one of the custom buttons to turn on the back screen as the primary screen I believe...
    I haven't tried that, but that approach should work.
    Leave it in Auto mode until you want to do that, then hit the custom button and use the loupe.
    Try that and see if it works.
    ---Michael
    a7r, a7rII, FE 16-35, FE 24-70GM, FE 70-200, Loxia 21mm, 35mm, 50mm
    Mar 2009
    947
    Quote Originally Posted by mjm6 View Post
    ---Michael
    Thank you. I will try that.
