Results 1 to 7 of 7
Thread: Check your adapter mounts
    23,623
    2555
    I have 4 adapters and all of them the mounts where lose. 2 Metabones 1 Novaflex and the Sony adapter I had to tighten down every one of them with a small Phillips head. This could lead to many issues. These are all brand new. These are all on the lens side of the adapters . Get your screwdrivers out and check them.
    www.guymancusophotography.com
    Feb 2010
    Nashville, TN
    172
    Re: Check your adapter mounts
    Guy, thanks for the heads up!
    J. Paul
    330
    130
    Thanks Guy all mine (n=6) are tight.
    k-hawinkler's Avatar
    Dec 2009
    The "Land of Enchantment"
    3,298
    Hmm, I may be mistaken but IIRC some adapters can be shimmed and adjusted.
    So, do they have to be tight? I simply don't know.
    For example I have been given the choice to send in my Phigmenttech.ca adapter so that it gets upgraded for that purpose.
    https://www.phigmenttech.ca/lmnex/in...age=FAQ#adjust
    With best regards, K-H.
    Oct 2009
    123
    I checked my Sony LA-EA3, all screws tight. My Metabones M to E mount adapter seemed tight, but I was able to tighten the screws a 1/2 turn or so (using a 1.5mm hex key).
    I'm having second thoughts on the Metabones. There's almost certainly a recommended torque setting. The screws may not be designed to be fully tightened, to allow for thermal expansion.
    If the mounting plate is loose, obviously one should tighten the screws, but not all screws are designed to be fully tightened.
    Ithaca, NY
    3,538
    Quote Originally Posted by k-hawinkler View Post
    I may have to do the same with my Phigment adapter which does not reach infinity.
    Carl
    Gallery
    Santa Monica, CA
    2,272
    2
    "There's almost certainly a recommended torque setting. The screws may not be designed to be fully tightened, to allow for thermal expansion."
    Torque recommendations are normally set based on the bolt/thread material and thread size, to ensure that the fastener is tight enough not to loosen, but not so tight as to strip the threads. I think it unlikely that adapter designers would expect fasteners to be looser that proper to shim a lens.
