Results 1 to 4 of 4
Thread: Canon FD - issue or no issue?
    Senior Member Rawfa's Avatar
    Nov 2008
    Rio de Janeiro
    2,393
    Hi guys,
    After seeing some shots taken with a 7R and a Canon FD 20mm 2.8 and I ended up ordering one (along with a 50mm 1.4 and a 135mm 2.8), but doing a little bit more research Iīv bumped into a website where this guy is saying that most adapters for Canon FD to e-mount are hell to use because of a lock that itīs hard to get to work or something...it was not very fundamented but he was not happy and recommended having one FD adapter for EACH lens. Can anyone comment on this? It sounds kind of crazy.
    Ithaca, NY
    3,538
    Re: Canon FD - issue or no issue?
    Quote Originally Posted by Rawfa View Post
    Hi guys,
    I just turn the lock ring to open position, mount the lens in the adapter, and turn the ring to lock position. I have the Fotodiox FD to NEX adapter. No problems switching lenses.
    Carl
    Gallery
    144
    Hi Rawfa,
    The issue is with the stop down mechanism on the FD lenses.
    The adapter has to be in the unlock position.
    The lens is engaged in the correct location by looking at the notch in the lens mount and the adapter.
    The lens is mounted and then the lock (on adapter) is moved into place and the lens will open to the largest opening and then the f stop is in manual mode to be rotated.
    Sounds complicated but once you know the procedure it is automatic.
    Paul
    Nov 2008
    Rio de Janeiro
    2,393
    Thanks, guys. Apparently this reviewer didnīt know what he was talking about then Glad to hear itīs a false alarm.
