Results 1 to 10 of 10
Thread: AF Micro Adjust
    Feb 2011
    Eads, Tennessee
    1,035
    AF Micro Adjust
    I tried, in vain, to adjust the AF for my Sony 55mm lens and only after re-reading the manual was surprised to find out that this feature seems to be only for A-mount lenses when using an adapter. Am I missing anything? If this is the case I'll probably return my lens as its auto focus is biased forward. Seems like a real feature omission to me.
    Victor
    k-hawinkler's Avatar
    Dec 2009
    The "Land of Enchantment"
    3,305
    Re: AF Micro Adjust
    For which camera, A7 or A7R?
    With best regards, K-H.
    Feb 2011
    Eads, Tennessee
    1,035
    Re: AF Micro Adjust
    This is for my A7r. AF Adjust is not available showing a '-' and when an attempt is made an error screen occurs and says that function is not available. The manual says this is for A-mount lenses used with the Sony adapter. Very disappointing......
    Victor
    Dec 2009
    3,305
    Re: AF Micro Adjust
    Doesn't the A7R only have CDAF?
    If true, how would microadjustment work?
    Feb 2011
    Eads, Tennessee
    1,035
    Re: AF Micro Adjust
    Don't know why that would matter. It does, apparently, work with A-mount lenses and the Sony adapter. The manual does discuss this feature.
    Victor
    Dec 2009
    3,305
    Re: AF Micro Adjust
    Isn't there PDAF involved?
    As I understand it CDAF works straight of the sensor, so there is nothing to adjust.
    Feb 2011
    Eads, Tennessee
    1,035
    Re: AF Micro Adjust
    You are correct..... the adapter uses PDAF. So then as I understand it if I'm front focusing with my 55mm its not something I can adjust. Very disappointing.
    Thanks for the clarification....
    Victor
    Dec 2009
    3,305
    Re: AF Micro Adjust
    Quote Originally Posted by vjbelle View Post
    Victor
    Indeed, front focussing would be very disappointing.
    I would consider it a fatal flaw in the camera/lens combination and ask for a replacement.
    Also, have you tried to give it more time to focus correctly?
    Tim Ashley found that helped when using the A7 kit lens on the A7R.
    I only have the A7R and FE 35/2.8. My combination is tac sharp.
    Feb 2011
    Eads, Tennessee
    1,035
    Re: AF Micro Adjust
    Replacement lenses are a crap shoot..... Sony spits these out in large quantities and the odds of getting an acceptable copy could be fleeting. I also have the FE 35 and like it enough to keep it but this may be the end of the line for Sony lenses.... I can put the thousand bucks into something else. My Leica 50mm Summicron M is a great performer and I really don't need a lens with auto focus.... The other issue is that manual focus with the Sony lenses is very different from Leica's or Zeiss. Not as quick or easy.
    Victor
    Aug 2008
    Bruce Peninsula, Canada
    2,535
    184
    Re: AF Micro Adjust
    I agree, Victor. I even find it easier to focus my M lenses on the a7r than on my M9.
    Which is just as well because the main reason for buying the camera was to use my M glass!
    I don't have any FE lenses and don't expect to buy any. I have the EA4 adapter so I can use the a7r as a back up to my a99/A mount lenses if necessary.
