Results 1 to 13 of 13
Thread: Get a Grip
    Subscriber Member tashley's Avatar
    Jan 2008
    South of England
    3,295
    Get a Grip
    I just used the 'official' sony handstrap for the first time and I think it's both good and bad. Good in that it is lovely to carry the camera this way and that if you get it nice and tight, you get a real sense of mass coupling and a strong hold as your hand arches and tenses against the strap.
    Bad in that the way it fits is sub-optimal: the bottom plate attachment means that the camera has a higher centre of gravity but a smaller base when set down, and it may not be as good at controlling shake when on a tripod because the contact surface area with the plate is smaller and there are more links in the chain. Also because it is hard to get the strap both tight enough and correctly positioned so as to allow easy use of the various buttons, dials and the shutter. Some tweaking of what i have assigned where might help as will some tweaking.
    But overall, I think that when I get used to it, ti will give me better handheld results and in particular I think I'll be able to gain maybe 1/2 stop in handhold speeds...
    Anyone else tried one?
    Knorp's Avatar
    3,999
    Re: Get a Grip
    Tim, really - you're late to the (grip) party ...
    Kind regards.
    Bart ...
    Jan 2008
    South of England
    3,295
    Re: Get a Grip
    Ahh, thanks for letting me know, it must have slipped past me when it was discussed. I shall look it up and see what others think!
    k-hawinkler's Avatar
    Dec 2009
    The "Land of Enchantment"
    3,300
    Re: Get a Grip
    I have the grip, tried it, but it doesn't seem to help me. :-(
    With best regards, K-H.
    Knorp's Avatar
    3,999
    Re: Get a Grip
    Quote Originally Posted by tashley View Post
    Nah, just kidding you. The grip is IMO absolutely beneficial when handling large heavy lenses, but of course that's no news.
    However it has it's quirks, like that irritating protruding release button.
    You'll find out soon enough ...
    Really, it's a stupidly flawed design - still, I like it
    Kind regards.
    Bart ...
    Knorp's Avatar
    3,999
    Re: Get a Grip
    Quote Originally Posted by k-hawinkler View Post
    Of course the grip won't help you, K-H !
    That's because you're shooting with canons (Leica R glass ...) only manageable when mounted on massive tripods.
    Kind regards.
    Bart ...
    Jan 2008
    South of England
    3,295
    Re: Get a Grip
    I'm talking about the hand strap, not the vertical grip...
    Knorp's Avatar
    3,999
    Re: Get a Grip
    A hand strap ? Well, that's a complete different ball game ...
    Seems very nice and comfy.
    I like to hold the camera by the vertical grip in my right hand while holding the neck strap in my left hand in case the camera slips out of my hand, you never know what can happen.
    So a hand strap could be an option for me as well.
    Kind regards.
    Bart ...
    Manchester/Jerusalem
    2,652
    290
    Re: Get a Grip
    I have a Camdapter hand strap that I loved on my 5D3. On the Sony however it just doesn't work. You either have the strap tight on your hand but then can't get to the buttons on the back without being a contortionist or you have it loose and it's just too loose. Gave up and went back to an upstrap that I've used on my cameras for about 8 years.
    Santa Monica, CA
    2,275
    2
    Re: Get a Grip
    I'm pretty sure the Camdapter will work with the RRS base, and John Milich will provide a slot for a hand strap in his as well: http://www.getdpi.com/forum/561789-post42.html
    Senior Member mjm6's Avatar
    Jul 2009
    Sacramento, CA
    526
    15
    Re: Get a Grip
    Tim,
    I have that hand strap on my a900 (or something very similar). It's the only way I would go now.
    One thing is that it can still take a neck strap, so you don't lose that functionality with the hand strap installed.
    However, I removed that goofy tripod socked adapter plate and instead purchased a QR plate that has a slot in it to accept the bottom of the hand strap. In that form, it is perfect. The added plate on the bottom functions as a QR plate, and the strap connects to it directly.
    I just got the new RRS QR plate for the a7r, and it has the same capability to accept a hand strap, so I will be purchasing another of those to go on the a7r as well.
    I can walk around all day long with the a900 hanging from my hand comfortably. Something I wouldn't want to do with a neck strap.
    ---Michael
    a7r, a7rII, FE 16-35, FE 24-70GM, FE 70-200, Loxia 21mm, 35mm, 50mm
    Sep 2011
    1,069
    83
    Re: Get a Grip
    I got the Gariz case/grip, handstrap and neckstrap, and am really liking the set. The grip on the case definitely improves the standard grip and is also more comfortable. The handstrap is well done and unobtrusive. I am using the neck strap in on the base with a sliding clasp and this can be removed easily when not needed.
    The quality of the bits is also very good
    Jan 2008
    South of England
    3,295
    Re: Get a Grip
    Thanks for all the added info folks, I will be exploring some avenues: I think the strap is ag rest way to go but that the Sony one isn't 'quite there'....
    I have one arriving for my E-M1 tomorrow and why do I suspect that it will be better?!
