Results 1 to 15 of 15
Thread: Good compact flashes?
    Senior Member Rawfa's Avatar
    Nov 2008
    Rio de Janeiro
    2,393
    Hi, I´ve stared shooting stills for actor´s portfolios and I find my self needing a flash with the Sony A7. I have a very compact setting going on and I´d like to have compact TTL flash to go with it. Any tips? Looking are the current options I don´t have much to choose from, so I was thinking about the Sony HVL-F20M.
    Feb 2014
    East Amherst,NY
    2
    Re: Good compact flashes?
    Rafael
    I use the F20M with my A7r. It complements the size of the camera perfectly. When I need more power I use the F60M, however it makes the camera somewhat topheavy.
    Gregg
    8,498
    44
    Gregg, don't you need an adapter for that F20M? If so, how stable is it?
    Flash is the one thing that keeps me from replacing my 35mm SDLR gear with the A7R. The F20 can bounce but doesn't swivel … and none of the third party speed-light modifiers work on it.
    The 43 and 60 flashes are just to big, and their design makes them even more unwieldy on these small cameras.
    - Marc
    Oct 2009
    178
    8,498
    44
    Quote Originally Posted by deejjjaaaa View Post
    Looks just right!
    -Marc
    Nov 2008
    Rio de Janeiro
    2,393
    Looks good. Has anyone tried it? Does it communicate with the A7?
    8,498
    44
    Quote Originally Posted by Rawfa View Post
    It is new, so maybe not available yet. It says it supports Sony's TTL interface, so I assume it will, IF it is the new mount and not the old Minolta mount.
    - Marc
    Feb 2014
    Escondido, CA
    50
    Scheduled release for Sony mount is June 2014 @ $250 per press release
    Oct 2009
    178
    - Marc
    it certainly shall be some TTL supporing mount... hopefully a new one like on A7*
    23,623
    2555
    I have the Sony 43. Really nice flash. It's not that big but anything you put up there will be big in a way
    www.guymancusophotography.com
    Aug 2009
    724
    rawfa, I would suggest that you consider skinning this cat differently. While TTL has pros it also has cons. You might sooner or later find that you are moving away from TTL to manual control and thus asking yourself why you limited yourself to manufacturer's flash and paid big bucks for it when you could have had many options for much less money if you went manual. So consider using manual.
    Oct 2009
    178
    Quote Originally Posted by ZoranC View Post
    with TTL flash you can do both TTL and M - whatever suits the need, with M flash you can't do TTL... so unless it is a matter of money (or particularly bad flash itself - like HVL-F60M is complained about a lot because of overheating) and you are using only one flash on camera then TTL flash makes perfect sense...
    Plus Nissin (above) if I am not mistaken can do A mode too, most of pure M flashes nowadays can't and A sometimes is a useful thing when you want some automation, but don't want TT preflash.
    A7RII + FE55/1.8
    Aug 2011
    San Francisco
    889
    F20AM needs an adapter. F20M does NOT need an adapter. Yes it is quite stable.
    I use the demb reportage flash bounce card with it. Almost perfect combination, use it off center in portrait mode and half bounce towards the ceiling and half forward to very good effect. Best flash for the size and money!
    ___________________
    Po-Ming Chu
    POPHOTO
    Aug 2011
    San Francisco
    889
    I also have the 43 which I took apart to check to see what capacitor rating, looks like I won't be modifying it anytime soon!
    ___________________
    Po-Ming Chu
    POPHOTO
    Aug 2009
    724
    That is obvious.
    so unless it is a matter of money ... and you are using only one flash on camera then TTL flash makes perfect sense...
    Not as simple as you try to present it. First, once somebody gets into strobes for say portraits, like OP wants to, very rarely they end up staying on just one light and that quickly ends up in very big money difference that even those with deeper pockets can't ignore. Next, I doubt OP will limit himself to "on camera flash" if he is seriously interested in portraits. Last, but far from least, TTL can never replace human brain and often enough will fail that sooner or later OP will start using his flash in manual mode.
    In other words: IMHO rather than spending money on single TTL flash he would be better off getting for approximately same total amount two manual flashes, remote controls, and some modifiers.
