Page 2 of 2 FirstFirst 1 2
Results 51 to 58 of 58
Thread: Best performing 24 or 25mm on A7R
  1. #51
    23,623
    2555
    Re: Best performing 24 or 25mm on A7R
    Canon mount 25mm F2 ZE. So it's the DSLR mount
    www.guymancusophotography.com
  2. #52
    Sep 2013
    598
    Jerome, those tests are incredibly useful, very much appreciated! I found the tree image to be the most useful actually, as you wrote, very 'real world'. It shows that the very extreme corners do suffer even at f8 but it's not enough to bother me. Now if only it wasn't so large!
    You are welcome. I think that the Sony-Zeiss 24mm f/2.0 is actually a bit smaller than the Canon/Nikon-Zeiss 25mm f/2.0...
  3. #53
    Senior Member Show Performance's Avatar
    Dec 2009
    Austin, TX
    851
    5
    Just a few snaps with the Sony Zeiss 24/2. They don't really show edge performance but it is excellent. Looks to hold up right to the corner where it dissolves a hair.
  4. #54
    Dec 2009
    Austin, TX
    851
    5
    Whoops! Those were on the A900. Here are some more test snaps on the A7 with the LAEA-4
    Was mostly testing for center sharpness and bokeh but the first shot was stopped down to 5.6 and shows some good edge detail
  5. #55
    Nov 2011
    39
    If you don't mind the LAE4 adapter and going a little bit wider, then I would also recommend the Sony/Minolta 20mm 2.8. Its short and lightweight, focuses fast, sharp enough stopped down, and has wonderful Minolta colors. You will have to push a bit harder in post with this lens but the resolution and colors are there. The following pics were taken on an A99, but I would imagine performance on an A7 wouldn't be much different.
  6. #56
    Manchester/Jerusalem
    2,652
    290
    There was a rumour that metabones was looking at an adaptor with optics to fix the corner issues of rangefinder lenses. Roger Cicala from lensrentals was hinting about it a while back. I wonder if it's an idea that died or it's in progress.
  7. #57
    Subscriber Member Chuck Jones's Avatar
    Studio City, CA
    700
    18
    Quote Originally Posted by nikonf View Post
    I am looking for the best image quality possible for the A7R.
    Does anyone have any real work experience with the Zeiss 25mm f2 ZF?
    A friend told me he is getting good results with the Leica 24mm f3.8 Elmar-M ASPH.
    Is this possible? I thought the Leica wide-angles were not working well on the A7R sensor.
    Which 24mm retro-focus lenses work well on the A7R?
    Sadly, the only old 24mm I have is a FD Canon 24mm f2.8 SSC.
    Any chance this would work for now?
    I truly appreciate any suggestions.
    All the best,
    Mike
    Mike, try it, I think you will like it. Even the 20mm f/2.8 FD is fantastic on A7R.
  8. #58
    Feb 2009
    1,083
    6
    Not sure where you can put Canon TS-E 24mm in this equation for this thread, isn't it on par with those Zeiss WA lenses such as 21mm?
    Tareq
