Results 1 to 4 of 4
Thread: Solution to avoid camera shake when shooting telephoto lenses with A7r
    Apr 2008
    Hong Kong
    487
    I have been searching for a solution to shoot my Sony 70-300mm. It's very hard for me to get a pin sharp picture at range over 200mm until I borrowed this from a friend to try. Markins: Home of Markins Q-Balls >> VR10S
    It does add a bit of weight (254g), but it's more than acceptable for me to ensure sharpness at all range. Highly recommended if you shoot over 200mm focal length often.
    860
    76
    Re: Solution to avoid camera shake when shooting telephoto lenses with A7r
    Yat Really Right Stuff makes a similar contraption except theirs has an adjustable height on the front lens support. The combined tolerances of 2 lens mount connections (considering adapter) and the high resolution of 36 mp is probably what's causing the need for extra support on medium telephoto lens to get critically sharp images. I am a little surprised it is needed for 300mm but I guess I shouldn't be. I know the L bracket on my Leica S2 in portrait orientation is not stable enough to provide consistent sharp images when using the 180mm even with self timer, MLU, remote release, and slowish shutter speeds (<125th sec).
    Mar 2009
    Massachusetts and Vermont
    947
    Thanks. How are you mounting your A7 to the device? By the tripod foot of the lens? It appears that you cannot use the device with an L plate.
    Apr 2008
    Hong Kong
    487
    Hi Mark, I will check out RRS too. I saw the Markins when I visited a friend and took it home to try. ;-)
    hcubell, with the 70-300mm Alpha lens, I use the RRS L plate on the LA-EA4 adaptor. I can do both horizontal and vertical fine.
