Results 1 to 5 of 5
Thread: Sony 4 adapter lossened up
    23,623
    2555
    I shot the other day in the studio with my 85 1.4 and noticed I had some movement on the camera side of the adapter . Rocking back and forth. When I was done wanted to make sure it was not the camera so tried it on the A7.
    I'm wondering if there is a way to tighten it down and make it a firm fit. No loss in images or softness just feels off to me. I may just buy a new adapter and actually I may just buy the 3 and use this 4 for AF only when I need it.
    Just wondering if anyone has run into this and found a way to tighten it down. It's not the camera mount as I tried every lens I had.
    www.guymancusophotography.com
    Brooklyn
    4,043
    1253
    Re: Sony 4 adapter lossened up
    is it rocking as in rotating? or actually pulling away from the flange?
    23,623
    2555
    Rocking when rotating
    Jun 2012
    58
    wait, what???
    Rocking= pulling AWAY from the camera mount by some perceptible amount-- are you saying in rocks WHEN it also rotates?
    Or, are you saying it moves WHEN you manually focus, moving clockwise or anti clockwise, while remaining firm against the mount?
    I have an adapter for my canon RF 50mm f0.95 that has very slight rotational play, but does not rock in or out, and thus has no effect on the image-- so I live with it-- if it were any more than barely detectable when I turn the focus ring, Id probably replace-- but as it is, no worries.
    23,623
    2555
    Let's call it roational . Once mounted it goes clockwise counter clockwise. It never deprecated from the camera just play rotational
