Results 1 to 15 of 15
Thread: Anyone tried the Leica Macro Adaptor M on A7/R?
    Subscriber Member tashley's Avatar
    Jan 2008
    South of England
    3,295
    I have a 90mm Macro Elmar which works beautifully with a Novoflex adaptor on the A7R, but I don't have the macro adaptor.
    It looks to have some superfluous 'bits' on it for rangefinder coupling. I wonder if they get in the way? Given that otherwise it is just an extension tube, does anyone have any suggestions of something else that might work well?
    Senior Member mjm6's Avatar
    Jul 2009
    Sacramento, CA
    526
    15
    Re: Anyone tried the Leica Macro Adaptor M on A7/R?
    I'll check when I get home. I haven't tried the adapter yet, but the 90ME works very well on there.
    I was thinking that there might be a M--->M adapter (close focus adapter) available in generic photo products land that would make a good 1:1 adapter for the 90ME. Haven't looked around for one yet, though.
    I'm guessing it'll work, because the bits are designed to cover the normal viewfinder mostly and so they should not interfere with the grip when installing it.
    ---Michael
    a7r, a7rII, FE 16-35, FE 24-70GM, FE 70-200, Loxia 21mm, 35mm, 50mm
    Jan 2008
    South of England
    3,295
    Thanks! Would love to hear. Am going to order some Kenko E mount extension tubes and try them on the ME with M>E adaptor....
    Jul 2009
    Sacramento, CA
    526
    15
    Darn it, I forgot to pull it out last night and try it... I promise I'll do it tonight unless someone beats me.
    jonoslack's Avatar
    East Anglia & Cornwall (UK)
    11,778
    Hi There
    Is there a problem using the Voigtlander VME adapter? I'd have thought that was a much better bet.
    Just this guy you know
    Jan 2008
    South of England
    3,295
    Thanks Jono, I'll look it up - I didn't know it existed!
    Godfrey's Avatar
    Jan 2009
    Near San Jose, California
    7,929
    Hi There
    A simple macro tube on a Novoflex adapter is likely more rigid than the variable focusing helicoid of the Voigtländer and other similar adapters.
    I have used the Micro-Nikkor 55mm f/3.5 pre-AI with matched PK-13 (?) extension tube on the A7, fitted to the Novoflex NEX/NIK adapter. Very rigid and precise fit, works perfectly.
    Godfrey - GDGPhoto Flickr Stream
    Jan 2008
    South of England
    3,295
    Yup, I think I'm going to go Kenko, since you get a pair of tubes that can be used separately or together. With my Foldio portable macro studio I'll travel with an entire 56mp macro setup including lighting in a briefcase. Nice.
    Jul 2009
    Sacramento, CA
    526
    15
    The Leica macro adapter works perfectly. No interference with the grip or the L bracket that I use.
    I don't have a grip for it, but I don't think it would interfere with that either, as everything is on the top side.
    Jan 2008
    South of England
    3,295
    Thank you for looking into that, very kind. I think that the 'smarts' in that adaptor are just the RF coupling. The rest is really just am extension tube. So maybe all I need is the Kenko or similar?
    jonoslack's Avatar
    11,778
    I've not used the VM adapter, but I have used the Hawks bay adapter - much cheaper - there wasn't any movement noticeable with that, and it has the HUGE advantage that if you turn it all the way the lens is just normal (as does the Voigtlander). An extension tube like the OUFRO means you can only focus in a very small range, and if something wonderful happens 15 ft away you've lost it.
    Seems like a no-brainer to me
    Godfrey's Avatar
    Jan 2009
    7,929
    I don't know about anyone else, but when I'm shooting close-ups in the 1:3 to 1:1 range, my camera is on a tripod, copy stand, or other fixture. There's no way I'm going to whirl around and snap a picture of something 15 feet away with it without taking the setup apart and reconfiguring the camera entirely anyway ... I'll just have to grab one of the other dozen or three cameras in the cabinet for that! ;-)
    Jul 2009
    Sacramento, CA
    526
    15
    Quote Originally Posted by tashley View Post
    Yes, there is no benefit to using the Leica adapter on a camera that doesn't have RF coupling or the ability to collect the 6-bit code for lens identification, I don't believe.
    ---Michael
    Senior Member kuujinbo's Avatar
    Oct 2012
    Pacific Northwest U.S.
    290
    6
    Had the regular Voigtlander M adapter, and now have the close focus VM-E. Even taking into account the focus helicoid, the VM feels more solid and stable than the regular adapter. When I got it was surprised the build was so much better (to me).
    Not sure if it will meet your needs as a true macro, though. Link to close focus distances by focal length:
    VM-e close focus Adapter
    Your Macro Elmar isn't listed, but the minimum focus distance will be quite close to the listed CV 90, going by experience using various non-listed lenses at the same focal length.
    "We're human, after all, and everybody's got something a little off somewhere." - Murakami Haruki, The fall of the Roman empire
    Apr 2008
    Mass
    306
    If you go for the Hawks just make sure you get the newest version for full frame
